Is this a normal S3 log?
stuart_tate41 Jun 4, 2013
  1. stuart_tate41
    stuart_tate41 Member
    84
    Hey guys ever since I bought the car I've felt it was a little slow, but I've put that done to coming from a 270bhp 320ftlb modified car to an unmodified 225bhp.
    Does this log look normal to you for a standard BAM S3?
  2. badger5
    9,431
    1,974
    195g/s if a realistic maf sensor is healthy - way more than a std 225 would be flowing..
    thats enough airflow for 243bhp
    log block 031 and 115 also
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It looks like your car has a map @ 243bhp (0.8 rule)
    Edit: Badger beat me to it...
  4. stuart_tate41
    84
    Interesting! seems to drive unlike my previous mapped car the boost seems to come in a lot harder than I would expect. I had worked it out to 243 but I thought that was optimistic!
    Shall I log 002,031 and 115 together in a 3rd gear pull?
  5. stuart_tate41
    84
  6. stuart_tate41
    84
    Only difference from the 1st log is now I have done the N249 delete (Which should affect G/S should it? )
  7. badger5
    9,431
    1,974
    i suspect either a Really good motor or an over reading maf..
    boost requests pretty std as is fueling (lean as std)
  8. stuart_tate41
    84
    Sounds good! I might try another MAF will a MK4 R32 by the same MAF? I think they are both 80mm?
  9. superkarl
    superkarl MAN OF STEEL
    9,430
    2,399
    i used to log 191g/s consistently on stock map.
    so you can rest assured that its running well.
  10. badger5
    9,431
    1,974
    no.. dont think they're the same..
    sensor element inside should be 049 last 3 digits
  11. badger5
    9,431
    1,974
    thing is rest assured you say...
    not 100% that
    I have seen a few times high apparent g/s but not a real g/s when equating to actual power measured.
    It could be that good tho, seen that also.
    narrowband maf on wideband car reads higher, but not real g/s
  12. stuart_tate41
    84
    Ahh the 32 one is 047
  13. superkarl
    9,430
    2,399
    fair point. But his logs don't display anything bad in this case
  14. badger5
    9,431
    1,974
    no, but nor do an over reading maf..
    dyno confirmed Actual power.. and over reading maf is obvious then.
    hopefully its just a really good one.. :)
  15. stuart_tate41
    84
    Going to try and borrow a MAF and try again. Just want to get it all sorted before I get a remap :)
