Is this a big Job
tonybolony Mar 4, 2014
  1. tonybolony
    tonybolony Member
    138
    So before this Car i have a B5 Bi Turbo, which i blew up and was able to replace the Turbos by myself, so i am not shy of a big job, and i coped well. But now i have picked up a 4.2 V8 Beast that has issues, and again am no shy of getting my hands dirty.
    My question is is this a bigger job than the turbo replacement on my B5?
    The Issue with this S4 B6 is it will run for 15 mins, then it dies, i have the Report, naturally a garage quoted me stupid money.
    Can someone tell me what is the issu, what it entails, and will i be able to do it? , many thanks in advance
  2. quattrojames
    14,068
    585
    You need to decipher those fault codes, and then establish what is wrong with it.
    Category:Fault Codes - Ross-Tech Wiki
    Whether it is a "bigger" job than turbo replacement on a B5 is hugely subjective, least of all dependent on your interpretation of "bigger"...
    Furkz likes this.
  3. 666markyboy
    666markyboy Well-Known Member
    1,240
    60
    How does it run for those first 15 mins ???
  4. Ian2012
    Ian2012 Active Member
    473
    29
    Depends on what needs doing i was always told that on the bi turbo it was engine out to do the turbos?
  5. tonybolony
    tonybolony Member
    138
    yeah it was an engine out on the B5 i have :)
    as for the question on how the B6 runs, it seems to run ok for that 15 mins, i am wondering if its the tensioners?
  6. 666markyboy
    1,240
    60
    Odd that it should run fine for 15 mins and then just die.... the ECU hasn't got wet has it ?? common fault on the B6
  7. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,750
    165
    Crankshaft sensor? I've heard of these failing when they get hot and work again when cold. We currently have this on a Transit at work and my dad had it on an older Saab, Vauxhalls suffer too.
  8. THQuattro
    THQuattro Site Sponsor Site Sponsor Team V8 Team V6 VCDS Map User Gold Supporter Team Silver Team Panther Audi RS4 Audi S4 quattro Audi A4 Audi Cabriolet Owner Group saloon S-line owners group Team Avus Silver Manual
    1,704
    1,134
    Ive just had to replace a Crank Sensor on a 2004 S4.
  9. tonybolony
    tonybolony Member
    138
    just to revive this, as i have been away, so as i said start it up and its running , and did so for about 10 mins, until i switched it off, however i hear a really funny noise in the engine? almost lke a tapping as if something is lose anybody help with this, have the tensioners gone maybe?
  10. DieselJake
    DieselJake Well-Known Member
    2,941
    751
    0:04 suggests your S4 has eaten a dog.
    ... sorry I'm useless when it comes to problem solving.
  11. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Multiple missfires indicates that the chains are stretched or the tensioners are gone. How does it sounds when starting from cold ? It's a engine out job to do the tensioners in the s4 + parts are not cheap either !
  12. tonybolony
    tonybolony Member
    138
    That was it starting from cold, that's how it sounds. is it really an engine out job? i had to do that with my B5 that was a bind
