IS THERE SUCH A THING.........
AUDI TURBO May 8, 2008
  1. AUDI TURBO
    AUDI TURBO Member
    577
    .Im soory to bring this up again but as i said before my jetex exhuast system is annoying me it so quite and it feels a waste of cash. i want a roaty sound. So is there abolt on replacement that will remove my side baffel box. if this was a normal car and it was in the middle i could obviously just attach a piece of straight pipe. but it fit behind and to the right of the back box. im not saying i want hi im chav loud but i want this foot to floor and little smile comes on face loud?? HELP!! Im serious if this isnt sorted soon im going to sell the system and buy another better one
  2. Broken Byzan
    13,237
    465
    That is probably your best bet, get a custom one, thay can more or less make it sound however you like
  3. AUDI TURBO
    AUDI TURBO Member
    577
    well that was a waste of £440.
  4. Lee Goodall
    Lee Goodall Active Member
    2,279
    I had a Powerflow cat back system made up and the sound is exactly what I was after.. explained what I wanted and they did the rest. It's probably louder than most people would want but I love it!!
  5. AUDI TURBO
    AUDI TURBO Member
    577
    how much was that??
  6. Lee Goodall
    2,279
    About £400 I think.. they've got loads of options too so def worth a look.
  7. AUDI TURBO
    AUDI TURBO Member
    577
    MIGHT JUST CUT SOUND BOX OUT THEN CHEAPER
  8. AUDI TURBO
    AUDI TURBO Member
    577
    GOOD NEWS!!! spoke to jetex today for abouy £50.00 inc p+p then can send out s/steel bend and straight pipe etc to bypass the sound box. ill let you know how i get on !!!!!1
  9. AUDI TURBO
    AUDI TURBO Member
    577
    DONE!!!!!!!!! middle box gone. wow it loud,...........................................
  10. docurley
    4,073
    88
    Sound like you have gone from one extreme to the other.
  11. AUDI TURBO
    AUDI TURBO Member
    577
    nope it sound mint!!!!!!!!!!
  12. RICH2JOSH
    RICH2JOSH Member
    78
    Has this affected your petrol consumption in any way?
  13. aragorn
    18,579
    868
    an exhaust should have no bearing on fuel consumption whatsoever tbh
    It may be the case that on a non-turbo engine, with a badly designed manifold, you would lose some midrange torque by fitting an exhaust will less restriction than standard, which may result in reduced fuel consumption due to the engines reduced performace as you'd tend to put the welly in more ;)
    On a turbocharged car (and on a nat asp car with a properly designed manifold) you basically want the largest pipe possible to get rid of the gasses and to make the engine as efficient as possible.
  14. RICH2JOSH
    RICH2JOSH Member
    78
    Kind of makes sense Aragorn, but I was comparing the noise you get from a peirced back box to this style of exhaust which from personal experience sank the juices from my old astra Gte.
    I suppose if the gasses ar being dispersed of optimally, there should be no reason for the fuel efficiency to change.
    Rich
  15. AUDI TURBO
    AUDI TURBO Member
    577
    i dont know if this to do with my pipe split(see other thread) but from £10.00 i get 40 miles!!!!!!!!
  16. Broken Byzan
    13,237
    465
    WOW. !! I could do that flat out, but something is wrong
    I have managed 60 miles on £20 before, even 40 miles on a tenner is still 20mpg ish, you are probably enjoying the noise a bit too much
  17. AUDI TURBO
    AUDI TURBO Member
    577
    well i got a hole in my dump valve pipe?? w i know im abit right foot heavy put im not driving flat out all time?? any suggestions??
