is there a choke on a4 1.8Ts? tickover normal when cold
jamesey Nov 17, 2013
  1. jamesey
    jamesey Member
    98
    hi do these a4 1.8ts avj have a automatic choke anywhere now its cold i can start the car ok but the revs are still around 800 rpms , surely that should be higher? does anyone know?
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,751
    165
    Could be related to your high emissions possibly? Poor plugs? too rich? etc
  3. S4_dan
    2,751
    165
    Do you have issues starting the car when it's warmer outside?
  4. Broken Byzan
    13,237
    466
    if the CTS is faulty, it's possible it's not reading the temp as low as it actually is, thus not apply the cold stat strategy
  5. jamesey
    jamesey Member
    98
    ive just fitted a genuine tmp sensor the one at the back of the head and its still the same , not got the error code now that told me it needed a sensor.
    it starts the same when warm , starts ok hot or cold , i do have a flat spot whilst accelerating but maybe something else.lol
  6. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Fuel injected cars don't have a choke, they use temperature sensors (intake temperature and coolant temperature) to determine when they need to inject extra fuel for a cold start.
    Try doing a FULL VCDS scan and see what fault codes it shows.
  7. Mike_B
    Mike_B Active Member
    533
    47
    Where's your flat spot?
  8. jamesey
    jamesey Member
    98
    hi , my flat spot is only every now and then and its usually when its semi warm when im acelerating hard
    got a code tonight on my obd scanner it said 16502 coolant sensor low?
