Is the Intake Manifold of the 1.9 Tdi 130 made of Aluminium??
YSN Oct 10, 2013
  1. YSN
    YSN Member
    93
    Hi everyone, I drive a B6 A4 Tdi brilliant car. However its on 113k right now and the EGR and Intake Manifold could do with a clean.
    I want to go down the Mr Muscle foam oven cleaner route but I know it eats aluminium. Just wanted to ask what material the EGR and Intake manifold is made of before I go ahead.
    Any help would be appreciated!
    Thanks guys,
    Yas
  2. Max M4X WW
    Max M4X WW Member
    139
    I'm no expert, but I would say they are some sort of aluminium/alloy. To be honest I cant see how a household cleaner would do much to it, its very thick material! When I did mine on my old Audi 80 I just scraped most of it out and used oven cleaner I think.
  3. YSN
    YSN Member
    93
    Thanks for the reply buddy, I tried the oven cleaner method it was ok but only for loose bits. IMO When I used the blow torch to burn it all off in the end I thought why did I even bother with the cleaner etc but there was a LOT of smoke lol. The oven cleaner is good for other things but for a gunked up intake manifold I must say blow torch FTW.
  4. adamss24
    adamss24 Well-Known Member
    4,557
    394
    I use the barbeque method, works every time...
  5. YSN
    YSN Member
    93
    lol what is the BBQ method?
  6. adamss24
    4,557
    394
    Barbecue ! You remove the inlet, soak in a bucket with diesel for a while then put on barbecue to burn the carbon deposits ! Don't go mad with the flame, i use a blow torch to initiate the burn then the flame will do the cleaning ! Power wash to remove all carbon and refit with a new gasket...That's all !
    weasle1uk likes this.
  7. YSN
    YSN Member
    93
    That's similar to what I did, but my one smoked up the whole place. I first tried to use "gunk degreaser" but that was taking too long and didnt actually work.
  8. Some Avgas and some flexible wire brushes...
    took a while but boy did the crud come out!!
  9. YSN
    YSN Member
    93
    I used a blow torch after I used it I was thinking I should have used that in the first place because its more quicker and effective.
