Is the gear knob fitting the same in the 8l & 8P chassis?
MikeA3 May 14, 2008
  1. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    Just thinking that as my gearknob's a little worn, I could replace it with the new one from the new (8P) S3, no major difference that I can see but the new one comes with a small S3 logo badge in it (similar to the badge in the 8L S3's steering wheel) so I thought it might look good.
    But.. will it be a straight swap? - Has anyone tried this?
  2. scott_johnson
    scott_johnson Audiless
    876
    Its a perfect fit, only you have to staple the gaiter to the oringinal base
  3. MikeA3
    1,178
    Thanks,
    my current one is still ok for the moment, it's just the leather is quite scratched - I guess my S3's last owner must have either been Mr T or pat evans from eastenders (shudder)
  4. scott_johnson
    876
    lol. if you do search i actually posted the same question.... also a guy did it and posted pics up. looks absolutely MINT!!!!
  5. fingermouse
    fingermouse thats me
    3,974
    110
    done it no probs, just the lower plastic bit to swap over, i got one off ebay brand new 50 or 60 quid
  6. fingermouse
    3,974
    110
    oh it was under rs3 gear knob .............. typical
  7. MikeA3
    1,178
    well £50 - £60 sounds better than £100+ from vag parts (god knows what audi would want for one)
    I think i'll keep an eye out on fleabay for one
  8. 1animal1
    9,976
    make sure you buy the ambient lighting..so that you can see it:beerchug:
  9. SHarper
    SHarper than most
    35
    I have a gear knob exactly the same as the one next to the Audi-sport.net banner at the top of the page. Its been in the door pocket since the day I got the car approximately two years ago. Does anyone know what its off? I think it's either TT one, or a R32 one.
  10. jm-baker
    jm-baker Member
    230
  11. j4jon
    j4jon Member
    704
    Sharper, if you don't want the knob i'll buy it off you?
  12. j4jon
    j4jon Member
    704
    I think it may be off a TT
  13. Its definately off of a tt, they come in 5 or 6 sped and are a buger to fit. you have to remove you old on, cut the part of it off and araldite the new knob to the old stem piece. then use a tie wrap to secure the gator. then you have to remove about an inch of your actual gear stick. then araldite the whole thing onto the top. it looks realy good when finished. if youve done it properley.
