IS THE FACTORY FITTED EXHAUST STAINLESS OR MILD STEEL
SCHOLESY83 Feb 23, 2013
  1. SCHOLESY83
    SCHOLESY83 Member
    42
    Hi,
    Does anyone know if standard exhaust on the S3 is stainless steel? 2007 model in particular?
    With the price of it, one would assume it is!!
  2. mjr901
    mjr901 Guest
    I have a full system from a 3 door 2012 S3, its done less than 1k if your interested.
  3. SCHOLESY83
    SCHOLESY83 Member
    42
    Cheers. Will PM you if I go down that route.
    as for my original question, any ideas??
  4. mjr901
    mjr901 Guest
    mild steel, it's heavy....very heavy...
    Where as my Milltek was not...
  5. SCHOLESY83
    SCHOLESY83 Member
    42
    Going slightly off topic but how have you found the miltek? Any issues?
    oh and Audi service technicians says the standard exhaust is Stainless..... Hmmmm
  6. mjr901
    mjr901 Guest
    It's well heavy, I'm certainly no metal expert, but it's not shiny like the millteks, so I assume it's mild steel. Probably very wrong.
    As for the Milltek, Sounds good, but welds on the downpipe are almost certain to crack at some point and need re welding.
  7. Boon
    Boon Active Member
    441
    59
    Mild steel is magnetic wheras stainless is not... try a magnet on it
  8. mjr901
    mjr901 Guest
    just did the magnetic trick.
    All the pipes are not magnetic.
    All boxes are.
    So semi Stainless??
  9. Rom
    Rom Member VCDS Map User
    443
    Id think Audi use stainless for the exhausts. Toyota have done for years (apart from Aygo) so surely Audi would.
    There are many grades of stainless though, which is why they wont look like an aftermarket system. They use a higher grade, which is shiny. Obviously OEM are just interested in it lasting a long time, not looking shiny.
    Thats why exhausts are a lot less common to replace on more modern cars.
  10. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Stainless classification starts with 12% Cr content.
    Most exhausts are `18/8 grade` (18Chrome/8Nickel) which are Austenitic.
    Generaly 304 designation for exhausts.
    Milltek gives big gains but welds can crack.
    Make sure your warranty is sound.
    Spicy pizzas n garlic sauce work well.
    good luck
  11. SCHOLESY83
    SCHOLESY83 Member
    42
    Did the magnetic check too, I found that all pipes and both large boxes (mid & rear) were non magnetic - suggesting stainless. Cat and smallest box as well as the chunky bit straight after turbo connection were magnetic - suggesting non stainless.
    Thanks for your input guys.
  12. SCHOLESY83
    SCHOLESY83 Member
    42
    Disappointing to here about the Milltek cracking issue. Surely this is covered by their corrosion and manufacturing defect warranty??
  13. Bazzle
    Bazzle Active Member
    509
    98
    Some stainless pipes etc are magnetic. Normally those that are more malleable.
    Work hardening can also make austenitic stainless steels slightly magnetic
