Is the coolant temp sensor plug the same as the coolant temp sender?
drfeelgood Aug 12, 2010
  1. drfeelgood
    drfeelgood Member
    225
    Just got a coolant temp sensor to replace my sensor, but its invoiced as a coolant temp sender? is it the same plug but can be used in both the temp sensor and sendor connection?
  2. 1animal1
    9,978
    yes its the same item, theres only two it could be, the other is a level sensor which comes with the entire bottle ;)
  3. drfeelgood
    drfeelgood Member
    225
    Ahhh good
  4. s3tle
    s3tle Member
    239
    i think if the car is pre 2000 the sensor should have a square plug and post 2000 are square one side and oval the other, not exactly what you asked i know, but worth knowing if the plug looks different when you come to fit it!!
  5. drfeelgood
    drfeelgood Member
    225
    I got it from audi so all is a ok. Its the correct plug :)
