Is the 8P s3 worth the money?
s3dave Aug 26, 2011
Thread Status:
Not open for further replies.
  1. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Agreed, the 8P sometimes feels like an overstretched Golf GTi ancillary wise
  2. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,751
    353
    I thought the 8L was pretty up-to-date until I got my 8P... different league.
  3. S3Alex
    10,697
    4,749
    The clutch was a real surprise,in that it barely copes with the standard torque values,and really is made of chocolate.
    Whether or not it was an attempt to dissuade people from tuning the thing or not,I have no idea,but it is pretty poor.
    The injectors are good for up to about 400bhp at a stretch,and the HPFP will get you to about 360bhp,but the engine will be well down on mid-range torque due to fuel flow restrictions....basically,the stock bits aren't that bad,it's just that when you really do go for some extra power,and by that I mean over 30% above stock,then you expect to have to change some things.
    Seats are good though...!
  4. jsws3
    jsws3 Member
    440
    You can tell it's a bank holiday weekend they have let the muppets out
  5. N8
    17,163
    718
    Dave taking on the 8P section with his opinions like his interior from 1999 = Fail
  6. sportstractor
    sportstractor Chugger
    2,709
    No :)
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Did you have to have a special manifold made for the gt30 as there all in one as standard arnt they....
  8. s3dave
    10,110
    736
    I would hug you if you were near.....:blush:
  9. S3Alex
    10,697
    4,749
    The stock manifold for the K04 is a one piece thing,so what you need is either the BSH kit here...
    BSH FSI GT Turbo Kit (Work of Art) - BSH Speedshop
    or the ATP kit here...
    GT3071R Turbo kit for FWD 2.0T FSI, MKV VW Golf/GTI/Jetta and Audi A3 (500HP) : atpturbo.com
    Neither are cheap,and both will require a LOT of work to make them fit a UK spec RHD car,as little things like the brake master cylinder get in the way.
    The BSH manifold can be bought separately,but of course you will still need the turbo.....in any case,right now,most of us would recommend a GTX3071 which would have to be sourced from the USA,as this offers the flow of a 3076,but with the characteristics of a 3071.
    Also add in RS4 injectors,RS4 fuel pressure regulator,and engine internals if you go for over 440lbs,and I would say budget on about £4k plus VAT and labour.
    Bottom end rebuild will add a few thousand more,and top end if you want more revs will add another couple.
  10. s3dave
    10,110
    736
    Cheaper than 8L BT conversion then, what are the rods good for?
  11. S3Alex
    10,697
    4,749
    Stock rods?.....about 450bhp and 440lbs
    What's the price of the 8L conversion out of interest?
  12. s3dave
    10,110
    736
    With supporting mods 6k+
  13. Khufu
    Khufu Well-Known Member
    5,704
    31
    Nates got a stutter tonight.
  14. N8
    17,163
    718
    flippin iPhone it was a reeeeeeepost
  15. S3Alex
    10,697
    4,749
    That's probably the big difference then,as getting to 450bhp and 440lbs does not mean a bottom end rebuild.
    I did however forget to include a few bits...you'd need a bigger intercooler above 360bhp,and the Proalloy is about £900ish fitted,so I guess all in you'd be in the same general region,and obviously other bits you would need such as brakes,suspension and diff controller will add to the pain.
  16. s3dave
    10,110
    736
    Thats it N8 make jokes it doesnt hurt you know.....:applaus: stop taking things to heart....;)
  17. s3dave
    10,110
    736
    The gen2 controller seems a decent bit of kit, have you noticed a huge difference?
  18. s3dave
    10,110
    736
    It wasnt a repost theres different words in it....:sly:
  19. S3Alex
    10,697
    4,749
    If you've done all of the other things such as coilovers( I chose the kW v3 for mine,and you need to spend ages adjusting that to get it right),and ARB's and adjusted all of it to minimise understeer,yes it does make a difference,but I think that doing it as a first step would just be lost in the general understeer the car has from stock.
    The brakes are also a weak area after Stg2,as they do fade rapidly and most of the aftermarket pads such as EBC are no fix at all for that.
    I see you have a good brake kit on yours,so you'll know how much difference that makes.....the weight of the OEM stuff is amazing...my VWR kit was about half the weight.
    The thing is.....you start with a £30k car,and then spend easily the thick end of another £10k on all of this stuff,and yes,it's then a lot faster than an RS3 and pretty economical and user friendly,but above that,the costs ascend rapidly,and the gains are a lot smaller.
    By comparison with the Escort though,it's still relatively good value motoring!
  20. s3dave
    10,110
    736
    Ive had a mexico mk1 and like an idiot let it go for peanuts a few years ago....
    have you driven an 8l s3? in standard form the typical audi understeer is pretty bad, the r32 rear ARB sorted that its a perfect balance now...
  21. S3Alex
    10,697
    4,749
    Never driven the 8L to be honest,as at the time I had the Escort,and honestly that not only demanded your full attention driving it,but also your wallet's full attention to keep it fed and provided with parts.
    The suspension had an incredible appetite for rosejoints and damper parts,and sub 10mpg mileage was just daft.
    I know what you mean about Mexicos...those fetch very good money now......the Escort was a very good car for anyone entering rallying,which is where it came from,and where it went back to once I sold it.
    To build a good GpN car from scratch would be about £30k on top of the base car,and an engine would have been about £12k alone....keeping one on the road was entertaining but silly.
  22. s3dave
    10,110
    736
    Its not daft at the time though eh Alex...:),
    Im just about ready to test a manifold for frankenturbo in america, and with water/meth should be seeing close to 350bhp witch is decent enough for me,
    is your fuel consumption dire then Alex?
    btw what weighs the most between the 2 s3s?
  23. S3Alex
    10,697
    4,749
    The current S3 is about 1500kgs,and the weight never goes down when you change models,so I'd guess it's heavier.
    Fuel consumption can be as good as 35mpg,if I drive gently,or well down into the low 20s,but given the traffic,it averages 30mpg.
    WMI is another thing I will add,and also a Sorenson manifold is on the list,but I have the engine rebuild to get done and parts are holding that back.
  24. s3dave
    10,110
    736
    That is very good consumption for your set up, i guess there is a lot of lag....
    WMI if installed correctly with the warnings is a briliant mod
  25. S3Alex
    10,697
    4,749
    No more lag than the original K04....
    If you choose the correct aspect ratio and so on,the lag is minimal,although what you will notice is the boost comes in around 500rpm higher.
    Keeping the stock CR does help of course...
  26. s3dave
    10,110
    736
    No lag difference between the standard ko4 and a generic GT3071 ??
    That is hard to believe, are you on a standard IC?
  27. S3Alex
    10,697
    4,749
    Honestly,there is very little difference.
    I've got a ProAlloy I/C and the CR is stock,and will stay that way.....those who've been in it or driven it have all said much the same...power and torque arrive a bit higher up,but little if any extra lag.
    I've been used to mountainous lag on both my Cosworths(although ALS on the Escort removed that,but made the thing undriveable on a road)and this was a surprise.
  28. s3dave
    10,110
    736
    Brilliant then, well done..
  29. S3Alex
    10,697
    4,749
    Not me...Revo and AMD!
  30. s3dave
    10,110
    736
    Are you the only one on here that has upgraded the turbo then?
  31. paddy
    paddy Audi=No fault code, no idea
    5,184
    137
    S3dave
    You come over here on a wind up...you slag off the interior of the 8p on an 8p thread then click dislike for any one that replies in kind.
    Get a life mate. there is plenty of strife in the world without people like you stirring up trouble where there was non. If i was a mod i would have niped this in the bud straight away. it pretty obvious how it would pan out because people like you can dish it out but you cant take it.
  32. Peachy
    Peachy Member
    225
    23
    I've read page one of this thread and can't understand if some of it is a wind up, and if so how much :laugh:
    I've had an 8L and an 8P - I loved my 8L and upgraded for the simple reason that I wanted a newer and better version, and thats what the 8P is imo. Also they didnt all come with a flat bottom steering wheel, it was an optional extra/upgrade although I'm sure this has been answered anyway, am I **** reading all 3 pages of this odd thread lol.
  33. Lings
    Lings Active Member
    2,059
    31
    Just dislike him back lads .Hes probably bought 4 cans after scrapping his old knacker in
    akash_sky1 likes this.
  34. s3dave
    10,110
    736
    Look back at your posts...... you were the one who was getting personal.....so its you that felt a need not to take it lighthearted..
    Do the dislikes go against your image? if you want some likes i will find all your posts if you want?
  35. Lings
    Lings Active Member
    2,059
    31
    S3 dave go bed lad lol
  36. s3dave
    10,110
    736
    This is about S3s lingy...Not soot chuckers.......run along
  37. paddy
    5,184
    137
    Too much ginger beer i think..
  38. s3dave
    10,110
    736
    Ginger? I must admit Paddy your car looks well, got to love white...
  39. S3Alex
    10,697
    4,749
    Seriously?
  40. s3dave
    10,110
    736
    Cool some tried and tested setups then, whats your goal?
Thread Status:
