Is tesco Momentum worth a punt??
S3 Paul Nov 8, 2011
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    There is a new tesco near my work that sells it
    I usualy try to stick to V power, I just wondered if this stuff is any good??
  2. aragorn
    18,612
    872
    I use tesco almost exclusively, and its perfectly fine.
    I'm there anyway doing the shopping, whereas i'd have to drive to Shell and its in the completely opposite direction AND more expensive.
    Tesco also do 5p off vouchers pretty regularly, so it works out the same price as standard juice.
  3. superkarl
    superkarl MAN OF STEEL
    9,612
    2,481
    its 99 octane. better than standard in terms of knock reduction.
  4. <tuffty/>
    21,899
    4,206
    I have started using it as I no longer go past a Shell garage since changing my job... seems to be fine tbh
  5. S3 Paul
    2,825
    107
    Good news,
    Now all i need to do is convince the other half we need to spend £50 three times in short space of time for the 5p off vouchers !
  6. superkarl
    9,612
    2,481
    sometimes, like the other week, they have signs by products in the shop saying 'buy 3 tropicana 1.5l bottles of juice and get 5p off per litre of petrol'
    it changes weekly. its been juice and lynx body spray that i can remember
  7. colicabcadam
    colicabcadam Guest
    I've used it many times before in my Ducati, not many of them around here though....
  8. S3 Paul
    2,825
    107
    I will make it her task from now to keep an eye on this... there is a tesco near ours but the one selling momentum is near my work...
  9. s3matty
    s3matty Member
    174
    Tesco 99 ron momentum is THE BEST FUEL available
  10. jontymo
    jontymo New Member
    Very good fuel and is my preference even over vpower
  11. oubas2
    oubas2 New Member
    14
    i run my car on this never know if its good or not really
  12. JtotheD
    JtotheD Active Member
    907
    26
    I use this when I'm not by a shell garage, which is most the time, it's still 99 octane which is what vpower is
  13. oubas2
    oubas2 New Member
    14
    i think there was a test done by redline mag or fast car, abit chav i know but i think they gave tesco fuel the thumbs up
  14. jcs356
    jcs356 Brum brum
    2,734
    70
  15. I agree with all you guys, when I used to run forumula fords where every last hp is critical we did dyno tests with every higher octance fuel availible (from the pump) and tesco 99 came out on top, ran it ever since.
  16. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    No issues here, but then if you can run a diesel on used chip fat I don't suppose running different types of S/UL fuels should be too bad.
    I've always wondered whether Tesco fuel would put any extra strain on rubber seals (degradation) with its magic mix, but no evidence of this so pure speculation.
  17. S3 Paul
    2,825
    107
    Was strangely enough talking to an old boy yesterday about this... he had a wierd theory ( that would be almost impossible to prove...
    V power is the best out of pump fuel, Its made to be the best it can be,
    Tesco mommentum is UL made upto 99 ron with additives
    He seems to think that if the Tesco fuel is stored for a period of time ( over 6 weeks) it becomes better than the V power,
    Im not sure Fuel would mature with age like a good wine .
  18. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    I alway though that the octane level would reduce if the fuel was left for too long?
  19. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    ive used tesco 99 for ages now always feels better after prolonged use.
    A lil test to try. Get some 99 in for a few fill ups then get it nearly empty and try some normal bp fuel and ull see the difference
  20. Paradox1
    1,833
    88
    Don't use vpower or Tesco but I've been using sainsburys premium fuel as its a lot cheaper and high octane. no problems so far. my SIS put regular fuel in at it felt soo slugish
  21. Westy
    Westy Well-Known Member
    17,443
    1,105
    I read that Tesco fuel was never very consistent due to the fact that the octane level gets worse the longer it sits in the tank at a petrol station.
  22. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    I use a mix of Tescos and Shell and see absolutely no difference.
  23. Westy
    17,443
    1,105
    To be fair I dont think you'd ever be able to feel a difference. Have you ever seen any difference on Bill's rollers between Shell and Momentum?
    EDIT, oh and as if it matters what fuel you run when your WMI effective boosts the octane anyway! You might as well run 95 RON.
  24. beanoir
    beanoir Large Member
    2,171
    31
    Every Little Helps as they say...
  25. Westy
    17,443
    1,105
    You should be ashamed of yourself! ;)
  26. beanoir
    2,171
    31
    I am, thats nearly as bad as the joke "i want to name a street Skin Street so I can laugh at the people who live at number 4"
  27. Westy
    17,443
    1,105
    According to google maps there is the following road in the US "Skin Creek Road, Lewisville, OH, United States"
    Imagine if your skin creaked!
  28. beanoir
    2,171
    31
  29. aragorn
    18,612
    872
    I could feel the difference in my old high compression NA vauxhall 16v motor, so i cant see any reason why you wouldnt be able to feel it on a tuned turbocharged engine where its even more important.
    Knock causes the ECU to retard the timing and reduce requested load, meaning you'll get less boost, less timing and less power. The more tuned an engine is the bigger the difference. I'd bet you'd see a fairly substantial drop in power on a 300hp S3 between 95 and 98 octane fuel.
    edit: doh i just realised you were meaning between tesco 99 and vpower, rather than SUL and Regular!
  30. Westy
    17,443
    1,105
    :whistle2:
    Plus Welly runs WMI which increases the octane level.
    When I went to the Ring last year I did a lap with VCDS running and measuring ignition timing while on the 103RON stuff they sell out there. On the logs there was hardly any pull compared to on 99RON but I couldn't feel the difference.
  31. aragorn
    18,612
    872
    had it been mapped for 102 and you threw 98 in it though, you'd see a lot of pull and distinctly less power.
    I think MRC did a European S4 recently and the 102octane fuel gave about +30hp on a similarly tuned (~500hp) S4 motor.
  32. Westy
    17,443
    1,105
    Since I've been on a Stage 2 map the car has had nothing but 99 shell or the 103 stuff from Germany. It was mapped for 99.
    Last year when I did the test I was running with an ultra poo map that was running lean and ruined my turbo.
  33. Welly
    10,696
    130
    It was brown and sticky, like the oil that the turbo spat out....
  34. JoeD
    JoeD Member
    537
    Use to fill with V-Power, now I use Testo 99 almost every time, I hav'nt felt any difference.
  35. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    I use both as I have a Shell Garage and a Tesco Garage both near were I live and the only difference I see is the 12p a litre I save with the Momentum....
  36. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    I use Tesco 99,. I get more miles per tank and the car feels nicer to drive.
    I put some regular in not long ago and I could tell the difference.
  37. Jason.s
    Jason.s Active Member
    2,879
    348
    Vpower has better qualities than Tesco ie knock reduction as tested by a few tuners. But then does cost more and the rewards arent as great.
  38. aragorn
    18,612
    872
    The thorney test linked above seems to suggest the opposite...
    Ofcourse its quite a few years old now, so things may have changed.
  39. Routledge
    Routledge Wind Deflector Trend-setter
    392
    10
    Tesco 99 for me all the way. Clubcard points too ;)
  40. Jason.s
    2,879
    348
    Plus Thorney are sponsored by Tesco :p I mentioned it to Ali who owns Unit18 and he said it was the answer i gave on Vpower being better as carried out by lots of other independant tuners. Dont ask me who as i dont know lol.
