is tension on this cambelt ok(VIDEO)
vw754 Sep 18, 2013
  1. vw754
    vw754 vorsprung Durch Technik
    2,325
    58
    2.0 TDI CR.....JUST DONE CAMBELT,IS THIS OK...........MOV_0942_zps9b76c637.mp4 Video by vw754 | Photobucket
    ITS NOT DEAD TIGHT BUT ITS NOT LOOSE EITHER,IM SURE THERE NO SUPPOSED TO BE DEAD TIGHT ANYWAY..........TENSIONER IS SET TO WHAT IT SHOULD BE,BUT APPARANTLEY THE SPROCKETS CAN BE UNDONE TO GET THAT LITTLE MORE TENSION AT THE TOP,BUT IM SURE IF I DO THAT IT WILL BE VERY TIGHT....IT WAS BAD ENOUGH PUTTING THE BELT ON,AS IT WAS VERY TIGHT.
  2. hollow
    hollow Well-Known Member
    1,404
    162
    when i fitted my cam belt i actually moved the pointer round further than the mark on the tensioner as the belt did fell a little loose.
    too tight and it will damage the tensioner
  3. Zafi
    Zafi Well-Known Member
    1,243
    306
    That roller looks a bit dodgy with the black stuff partially stuck on it....
  4. vw754
    2,325
    58
    quite normal after fitting some belts apparantley,nothing to worry about,had it checked out all is ok....nothing dodgy lol....everything is genuine parts.
