Is stroker worth it?
vroomtshh Jul 31, 2013
  1. vroomtshh
    vroomtshh Active Member
    362
    49
    I'm currently in the process of gathering parts for a hybrid build.
    Im looking for a nice strong reliable motor, hopefully around the 350bhp mark.
    At this level, is the expense of a stroker worthwhile, or would I be better spending the money on some head work?
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    I wouldn't bother if your jut aiming for 350bhp. The boys going Stroker are all knocking on the door of 500bhp.
  3. Prawn
    11,443
    3,339
    A hybrid will spool very early anyway, and I think you'll still be limited on how much boost you can run early on due to the size of the exhaust housing, so you'd not be ble to use the additional low down boost, it the turbo would run out of puff sooner at the top end.
    Id stick with 1781cc for a hybrid
  4. superkarl
    superkarl MAN OF STEEL
    9,423
    2,382
    Agree with prawn.
    Strokers have their place with bigger turbos to spool them earlier whilst still making power, makes them more usable.
    On a small turbo, bot much point really. Better low-mid range torque, thats it
  5. vroomtshh
    362
    49
    thats why I was thinking of it. More mid-low range is always good. It's a fair expense though which could be better used eelsewhere.
    I wasn't sure as well if 350 was a bit of a push, and the extra capacity would help with that
  6. superkarl
    9,423
    2,382
    If youve got the money then do it.
    Were just saying its not as beneficial on smaller turbos.
  7. Nyteryda
    Nyteryda Nyteryda
    234
    350 from a hybrid k04 sounds a bit much ? .. thought they were good for around the 300 mark ..
  8. superkarl
    9,423
    2,382
    Nope, 350 is doable.
  9. slappy_dunbar
    slappy_dunbar Let's Do This
    245
    20
    Having tested our hybrid turbo on an increased-displacement motor for over a year, I think I can speak pretty knowledgeably on this question. And my recommendation would be to skip the expense unless you really value boost onset at 2700rpms versus at 3000rpms. Because that's the only benefit. Up top, the capacity limits are with the turbo hot side rather than the engine displacement. So you would net zero additional horsepower. The only change will be how the motor feels between 2000-3000rpms.
    Trust me, this finding is a disappointment. I'd had grand plans of introducing our own, branded stroker kit. But the modified motor simply doesn't wow me on this size of a turbo. I'd say your money is better spent on a WMI system.
  10. superkarl
    9,423
    2,382
    You could say it would be better spent on headwork. But a hybrid wouldnt produce anything considerable that high up so that would be even less worth the expense. If anything the stroker is a better idea than valvetrain. But still, not that worth it.
    Looking at the bigger picture, if you were considering a stroker on a hybrid ko4 with 350hp in mind, id say that money you were considering spending on a stroker kit (£2k?), would be better spent on a turbo capable of 350 more comfortably, that would be the wisest thing to do
  11. Nyteryda
    Nyteryda Nyteryda
    234
    jeez, wish i hadnt gone through all the hassle of 'big turbo' now for a few extra horses as its been a complete pain in the ass
  12. Prawn
    11,443
    3,339
    to be honest though, very very few will see 350 from a ko4 hybrid. 330 seems to be the typical figure most will produce.
    To my knowledge (in the UK - not sure about Dougs stuff in the states) mine is the only one that's produced anything above 350, with hardly any others reaching 340, so a safe assumed max for the ko4 hybrid still really remains around 330-335 as it was 3 years ago
  13. <tuffty/>
    20,995
    3,762
    Big turbo power delivery is different to small hybrid turbos... don't get fixated on peak power... area under the curve etc....
    This is very true... while a decent hybrid setup can knock on the door of 350hp it doesn't do it comfortably...
  14. vroomtshh
    362
    49
    thats what I thought. I'm not exactly bothered if it doesn't make 350. That's just the number I'm aiming for. I'd prefer not to go BT, because of the reasons you mention above. I don't want peak power figures to brag about. I want a quick, tractable, reliable (ish) car.
    Maybe I'm better waiting to see how the testing of the new tfsi conversion goes
  15. badger5
    9,423
    1,967
    More than once on one car?
    nope... they dont...
  16. badger5
    9,423
    1,967
    Exactly - Nail on head.
    Unfortunately, yours is the ONE which gets banded about as having done 350+bhp... (including you in your siggy, lol)
    Doing it Once, then turning it back to a "safer level" proves what exactly?
    I could say our lupos 332bhp k03 hybrid.. but no.. its not in reality although it has done it.. Its 300bhp solid, and 332bhp if turned into the stupid hot level.
    People latch onto the fact the power has been achieved once, on a cold run, non repeatable but then sent out on a lower level....... for reliability.
    the vast majority of k04 hybrids make a little over 300bhp, and some venture into the 320-330bhp range.... Realistic Dyno figures. Not fictional airflow based ones from logging alone.
    For the ~OP, invest in wmi with your hybrid... Essential ingredient for 1.8t's imho, especially small hotside hybrids. It will help you realise it potential safely
    comparison of a couple of very similar hybrid spec's one lcr one agu (prawnys as the gauge reference)
    You can see the boost and torque difference between them, and ones road car and the others track car, which will spend its time getting ragged on track, so appropriate level of tune to keep it together, that and no egt protection possible in agu ecu, unlike LCR. It is possible to get these figures as you can see, even on a tight arse dyno like mine, but the dice needs to be stacked and all boxes ticked for decent mods, added properly.
    USA/Dougs figures all fall into US happy dyno category, where they all seem to make atw figures where we get @fly figures from same hardware, same boost etc etc.... Accepting that for what it is.
    eg below:
    The tell tale for where inefficiencies creep in are where the mass air flow divide 0.8 correlation diverges, and this is where large, usually heat effect inifficiencies creep in.. Pushing a lot of air thru a small turbo hotside.
    Its all about the flow, AND thermal management
    tick these two boxes and it will be as good as it can with suitable mapping encouring it to do its thing. :)
  17. Neru
    Neru Member
    129
    9
    Whats the reason for yours producing such high power, my aim with the k04 hybrid is 300bhp which is a bit harder in Australia as our quality of petrol is lower than yours
  18. badger5
    9,423
    1,967
    a well built engine, well thought thru install, which flows well, ported clearanced hotside ... and sensible boost level.... Relatively low on torque but built for tractive power not headline torque as its a track car..... and some Prawny "magic" :)
    Some setups just "work" really well.... and prawnys is one of those rare beasties..
    Wellys on hybrid was mutant, and gops's lately was superb, and a couple of others I have tuned and dyno'd stand out from the majority which just dont often work so well... for reasons unkonwn.
    Prawnys has always been superb.. and is a credit to his attention to detail and building it right.
    Prawn likes this.
  19. v5 tt
    v5 tt Member
    87
    Hi mate im doing exactly that 2ltr stroker running a k04 hybrid ...
    reason being one i wanted a rebuild anyway and was going for
    a 1.9ltr but you can pick up fsi crankshafts pretty cheap
    so it just made sense to go for a stroker setup plus the fact
    any future turbo changes i,ll have the whole setup for BT...
    i will be running CP 83mm pistons 9,5 compression
    hopefully the build may start this month...
  20. badger5
    9,423
    1,967
    how cheap did you pick up a tfsi crank for then dude?
  21. v5 tt
    v5 tt Member
    87
    Got it quite a while back was about £100 from ebay then £20 30 for the correct gear from I.E
    so for the sake of just over £100 why not i,ll get it polished hopefully should be good to go
  22. Prawn
    11,443
    3,339
    Are you still doing your build V5tt? I seem to remember it was a great looking spec, anywhere near completion yet>?
  23. v5 tt
    v5 tt Member
    87
    Yeah iv picked up pretty much the last parts for the engine build so its just a case of
    getting it assembled so may make a start this month ....
    Having an ECU conversion as well i have the old narrowband so got a
    BAM ECU and loom
    Finally need to get my clutch so iv still got a bit on my plate to do
    but its getting there...
  24. ReDBull
    ReDBull Member
    217
    13
    How important are the AGU pistions to the mix?
  25. superkarl
    9,423
    2,382
    If my car hadnt have blown, heres what i wouldve done.
    Total engine rebuild, arp the **** out of it, stroker, 83mm cp pistons, rods, bearings the lot. Rebuild that and whack it in the car even with the stock turbo.
    Then, when id have the money for the next chapter, id do the turbo, mani intake exhaust etc.
    That would be an epic way of doing things, for me anyway.
    But no, il settle for a 1.8, and enjoy saying 'its just a 1.8 mate...'
    <tuffty/> likes this.
  26. vroomtshh
    362
    49
    Thats what I'm thinking of doing. I have a spare largeport engine. And I'm considering building it up like this and running it on hybrid.
    Then 'when' I get bored, I already have the foundations there. Or If I decide to sell, the foundations are there for the next person
  27. badger5
    9,423
    1,967
    awesome find!
    want one myself now..
  28. badger5
    9,423
    1,967
    not worth changing them unless you have to... but if you have them and have the motor apart a little more CR peps up the overall response.. in my experience.
  29. <tuffty/>
    20,995
    3,762
    Stroker in the Lupo :D
  30. badger5
    9,423
    1,967
    now there's a thought... immense acceleration in gear with that... hmmmm
  31. Scullies
    Scullies Well-Known Member
    1,543
    657
    I will still say my stroker is a 1.8t with a good custom tune :lmfao:
    No one can tell when the engine is closed up and not many will even notice a 2.0l crank next to a 1.8l :)
  32. v5 tt
    v5 tt Member
    87
  33. Scullies
    1,543
    657
    That crank is from a fsi engine and not the Tfsi. The difference being the 2.0 fsi n/a engine has a cast crank, same as the 2.0 8v mk4 golf etc.
    The Tfsi is a forged crank and looks a little different.
    It can still be used for a stroker build though :)
    heres a nice link with a lot of pictures showing the differences between 1.8t crank and 2.0t crank
    VWVortex.com - 2.0 TFSI vs. 1.8T crankshaft
  34. badger5
    9,423
    1,967
  35. superkarl
    9,423
    2,382
    tfSi crank is 1kg heavier that guy says.
    So fluid damper pulley pretty damn sensible thing to fit then
  36. v5 tt
    v5 tt Member
    87
    To be honest i cant say for sure ??? ...here is a nice
    reference from issam from vwvortex
    Handy for when your hunting down a stroker crank.....
    CAST 92.8mm Crankshafts
    w/out modification to oil pump gear (i.e. changing to work with 06A | 06B oil pump)
    • AZJ
    • AVH
    • BHP
    • BEV
    • AZG
    • BEJ
    • CBPA
    Basically any 2.0 8V Motor found in the MKIV or MKVI.
    FORGED 92.8mm Crankshafts:
    all require modification to go from 06F to 06A | 06B oil pump gear.
    • BPY
    • BMP
    • ALT
    • AXW
    • BMB
    • AWA
    • CDLC
    • CDLF
    • CDLG
    • CZRA
    :beerchug:
  37. v5 tt
    v5 tt Member
    87
    i think you will find its the forged crank its normally the diesels running the
    cast cranks
    all the same you still would be hard pushed to brake a cast crank
    but i opted for the forged crank as will probably most people
  38. <tuffty/>
    20,995
    3,762
    Shan't be on mine but it will all be getting balanced... std damper should be fine as long as the revs aren't too high...
  39. Scullies
    1,543
    657
    That ebay crank is definitely not forged. As well as 2001-2005 passat's weren't fsi. I bet its the same 2.0 cast crack from a mk4 golf.
    Seems Bill is right about the alt passat engine code being a 20v
  40. Broken Byzan
    13,237
    465
    ALT is the 2.0 litre 20V NA engine 06B designation.
