Is new set of bushings adequate?
jibbajabba Jan 30, 2008
  1. jibbajabba
    jibbajabba Member
    35
    Just wondering could I expect to get some stiffness back in my tired suspension by just replacing the bushings? If not I'll have to go the whole hog.
    Don't want to change the setup of the car.
  2. Nickynibbles
    Nickynibbles Damn it where's 7th gear when you need it?!
    845
    Do you mean the bushes? This wont make any difference to the performance of the dampers as the bushes are purely there to help secure the top & bottom mountings. You better off just replacing the whole damper as you'd have to take the old ones off to change the bushes anyway!
  3. jibbajabba
    jibbajabba Member
    35
    yeah sorry, the bushes.
    Won't replacing them tighten up the suspension again, or is it a case of sloppy, crashy
    and loose feeling suspension means springs, dampers etc
  4. Nickynibbles
    845
    The reason your suspension will feel like that is because the internals of the dampers are worn, changing the bushes wont sort this problem out. Just get new dampers to fit your existing springs if your not after an upgraded set up, or if your feeling adventurous a full set of coilovers will allow you set set your ride height exactly how you want!
  5. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Agreed. I had worn bushes all over the front of my B5 so I replaced all eight arms and their bushes; all the horrible knocking and banging noises had gone, and to be fair it did feel a little tighter, but I wouldn't say it improved the handling any. I noticed a small difference when being a little ambitious with the throttle on tight-corners and wet tarmac - before I had them done it was really easy to light-up the outside wheel and it seemed less prone to it once I'd had the work done, but the bushes were well and truly dead and the arms not so healthy either (there was a gas-axe involved in removing them) - overall though, general handling is no different.
    Regards,
    Rob.
  6. jibbajabba
    jibbajabba Member
    35
    Thats sounds familiar. My outside front seem to spin very easily, especially around the tight bends and roundabouts, and it feels like the outside wheel is moving all over the place.
    I might go and price the 8 arms and bushes to replace them and see how that fixes things up as I presume such a job from an audi dealer would be expensive to say the least. I have sports suspenion on my B6 so it is plenty low for me, just want the knocking and movement resolved.
  7. james0808
    james0808 Active Member
    3,548
    Got to agree with Nickynibbles,changing the dampers will totally transform the ride for the better.
  8. jibbajabba
    jibbajabba Member
    35
    Any suggestions on replacements? Audi OEM or thrid party? These wont alter ride height or anything will they?
  9. james0808
    3,548
    I would go with Bilstein or Koni but there is loads to choose from.
    Wont alter the height unless you change the springs.
  10. james0808
    3,548
    If you havent already i would put an RS4 rear anti-roll bar on too,very cheap from vagparts and make a fantastic mod.
