is my turbo working?!
steve bain Jan 6, 2011
  1. steve bain
    steve bain Member
    642
    hi all.
    bear with a bit here as the car is new to me so am not sure how they normally behave. It is a 1.8T T-reg A3.
    I feel it is not as quick as it should be and can't feel the turbo 'kicking in'. So my question is can you feel the turbo 'kick in' normally or is it a smooth transition. I can't hear a whistle either. Also is there a way I can test it? would a boost gauge how up any problems? I am used to 2 litre cars so am wondering if it just has less torque so doesn't feel as quick. It seems to run fine to me otherwise. it is on a good 144,000 miles! could it be the waste gate is staying open or something. I am getting vag-com delivered. Would this be able to test the turbo? Any pointers would be ace.
    also my gearstick is a bit sloppy and twists if that makes sense. Can a bush kit be purchased to sort this or is it something I will hae to live with?
    Thanks loads. Sorry if these are silly questions.
    Steve
  2. hi i have a audi tt 225 and have had a new turbo fitted the reason i had to get it was blue smoke coming out the back i didnt lose power tho i still got the whistle my girlfriends dad took the pipe off the turbo and put his fingers in and the turbines had about one millimeter of play and he said its knackered so you can try that bud davie
  3. steve bain
    steve bain Member
    642
    there is no smoke so i think that it is ok from that point of view, passing oil etc. I will check the blades and play this weekend. make sure it actually spins! anyone know the amount of play it should have? I know they normally have a tiny bit of movement.
  4. hi bud he told me there should be no play at all mine had hardly any mate andit was beat
  5. quattro1
    quattro1 Member
    639
    There should be a minimal ammount if play that is taken up by the oil.
    Id thoroughly check for boost leaks, unplug your n75 valve and drive it, see if theres any difference
  6. steve bain
    steve bain Member
    642
    ok. will do. I will do that tonight and get back
  7. steve bain
    steve bain Member
    642
    ok, so i disconnected it (not proper plug, but crimp on ones! i hate them!) It may have been quicker disconnected, but i think there was nothing in it really. It is worth mentioning the guy before the previous owner had a fancy waste gate and he took it off to put the plastic one back on. bit of a butchery of pipes around there too. So what should the difference be between plugged in or not? thanks for your help
  8. steve bain
    steve bain Member
    642
    also. how do i go about testing for boost leaks? i have a vague memory of spraying wd40 around the pipes and if the idle changes then there is the leak. is that right? cheers, steve
  9. quattro1
    quattro1 Member
    639
    Right so theres dodjy piping around the diverter valve ? Any chance of a pic? A boost leak here would make a pretty big difference to how ur car drives. As for checking for leaks just have the engine running and have a good squeeze all over any boost pipes u see and listen for hissing as you bend/squeeze the pipes.
    Did you say you didnt electrically disconnect the n75?
  10. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    plastic wastgate? do you mean diverter valve....
  11. steve bain
    steve bain Member
    642
    Maybe! Very new to this car and engine so prob getting names wrong. Will get pic soon. At work at moment. Thanks. For help
  12. Stanley
    Stanley Member
    201
    My car does this too.......
    Same car and engine.
    I suspect its N75/wastegate related but cant be sure as its intermittant.
  13. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    mine was quiet and slow before i had a remap etc
  14. steve bain
    steve bain Member
    642
    HA HA! does that mean I have no choice but to remap :)
    i'll get pics later on as have to go back to work. any advice on how the removal of the N75 should effect the performance?
  15. DaveA3
    2,370
    15
    get a vag-com and run some MAF readings and work out ur BHP. or plump a boost gauge and see what PSI ur at and vacuum also.
    and yeh u do want a remap ;)
  16. Stanley
    Stanley Member
    201
    I can hear the turbo spooling, but there is only a very slight dump noise but nowhere near as much as normal.
    Seems like the turbo is doing its job, but either N75 or wastegate is causing a problem.
    Perhaps time for an N75J/H valve.....
  17. Stanley
    Stanley Member
    201
    Oh and yes, you really do want a remap. Completely transforms the car.
    You will NOT be disappointed!
  18. quattro1
    quattro1 Member
    639
    Stan, check the robber hose that the diverter valve is attatched to, i had the same problem as u, this pipevhad a 2-3" cut in it!
  19. steve bain
    steve bain Member
    642
    hi guys. I finally have some pics. i am not sure what most of this stuff is or what it does though! I will spend some time checking all for condition too. So do i maybe need a new n75 too?
  20. <tuffty/>
    21,885
    4,203
    DV is the wrong way around for a start and as its an OEM one it may also be part of the problem and need replacing due to a split diaphragm...
    Looks like somebody has been playing about with this a little for whatever reason and put it back to 'std' prior to selling...
    I think its time a specialist looked at this mate tbh if you are new to it all... where are you based?
  21. steve bain
    steve bain Member
    642
    ah ******! he did say that the guy who owned it before him had a fancy DV and swapped it back to the original on before selling it. thats quite a big mistake! I live near plymouth, anyone good around here. I am a very hand on person and think nothing of stripping down and rebuilding an engine so am keen to learn rather than just pay someone. I just have no experience with this engine. For now i take it turning the DV around would be a good move to start with? thanks for your help. Steve
  22. steve bain
    steve bain Member
    642
    right i have ordered a haynes so i am going to get on this and get my head around how it is and how it should be. I will probably ask a lot of questions along the way so i hope you guys will be nice enough to advise when i get stuck. I think once i have done the basic checks (as in, make sure all pipes are as they should be and valves are the right way around!) i will then have it rolling roaded by a professional. But i don't want to pay someone to fix things i can work out mmyself. I will buy a boost gauge also to check that. thanks, Steve
  23. aragorn
    18,608
    871
    If there was no difference on removing the N75 then your turbo isnt boosting.
    It might be a leak, but when my A4 did that the penny valve had fallen off the wastegate arm inside the turbo.
    Replace the DV with a 710N from a TT, and see if that helps, just make sure you fit the new one the other way round!
  24. steve bain
    steve bain Member
    642
  25. quattro1
    quattro1 Member
    639
  26. steve bain
    steve bain Member
    642
    Sadly for the time being this has to stay as a budget project as it has quite a list of bits to sort out and i'll end up spending a fortune (plus i need to sell my old car first!). So i think it will have to be the oem one for now if you think the repo is a bad idea. Having said that its not exactly a complex device and i bet the repo is a copy of the forge. I could be the guinee pig to try it? :)
    I got my vagcom today and am terrified at the list it is going to throw up!!
  27. steve bain
    steve bain Member
    642
    Sorry for long post!
    so i have just done the scan with the VCDS lite and these are the codes which came up. Never seen so many! Obviously hasn&#8217;t been checked for a while. I have cleared the lot and will check again in a few days.
    HVAC woudn&#8217;t even work as it said there were too many!
    4 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    16500 - Shareware Version. To Decode all DTCs
    P0116 - 35-10 - Please Register/Activate - Intermittent
    00515 - Shareware Version. To Decode all DTCs
    30-10 - Please Register/Activate - Intermittent
    01262 - Solenoid Valve for Boost Pressure Control (N75)
    26-10 - Output Open - Intermittent
    Readiness: N/A
    so as far as i can work out from the google magic
    18010 - means at some point the battery has been disconnected. no problem
    16500 - coolant temp playing up. I know the thermostat is dead, but if this comes up again it says it may be the sensor.
    00515 - something to do with Camshaft Position (Hall) Sensor (G40). not sure what though
    01262 - Solenoid Valve for Boost Pressure Control (N75): Output Open
    RESULT! I am going to see if it comes up again but I have a good feeling about this. I did disconnect it and drive it though so it may be that! Do you think the N75 may be at fault if the code comes up again?
    This is what Ross-tech say.
    Possible Symptoms
    Reduced Power Output
    Boost Pressure too Low
    Possible Causes
    Wiring from/to Solenoid Valve for Boost Pressure Control (N75) faulty (Open Circuit)
    Possible Solutions
    Check/Replace Solenoid Valve for Boost Pressure Control (N75)
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    01372 - Shareware Version. To Decode all DTCs
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Shareware Version. To Decode all DTCs
    01369 - Shareware Version. To Decode all DTCs
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    00955 - Shareware Version. To Decode all DTCs
    09-00 - Please Register/Activate
    01134 - Shareware Version. To Decode all DTCs
    49-00 - Please Register/Activate
    interestingly fault 00955 is saying the key fob doesn&#8217;t work. All following codes are the alarm being set off by not turning the alarm off before unlocking with key!! Ha ha!
    And one last fault which wouldn&#8217;t clear. Hopefully the plug has come out or something and will be easy to fix. Hopefully the igniter isn&#8217;t knackered!
    1 Fault Found:
    00589 - Airbag Igniter 1; Passenger Side (N131)
    32-00 - Resistance too High
    So a lot of faults but hopefully some will clear and not come back.
    I swapped round the diverter valve and it I definitely better and I can now hear the turbo, but it might be in my mind! Now though the idle has become erratic fluctuating between 900 and 1100rpm. I read elsewhere that this can be caused by boost leak so the next job is to pressure test for leaks and fit a boost gauge to see what it is up to.
  28. s3dave
    10,110
    736
    Looks like you have your hands full, try and change one thing at a time and recheck the faults, or you wont know what worked, looking at the pics it looks like a meddler has been in playing, so dont rule anything out, i think boost leaks are a good place to start, and can be very hard to spot, a good sign is oily pipes..
  29. steve bain
    steve bain Member
    642
    If i am honest i secretly enjoy a challenge!
    like you say, one job at a time, nibble away until they are all gone. I hope most won't come back. This way i get to learn about the car and i know what does and doesn't work. At the moment i know most doesnt! even the reverse lights don't work!
    I have read up on making a DIY pressure tester to find the boost leak. makes sense to me and is a good reliable way to do it. Its all good. Some of the vacuum pipes i could pull apart by hand and decided in the dark in the rain was not a good time to start what was most likely a mammoth task! Car before was a 100% perfect mondeo. but it was so bloody boring! :)
