Is my cutoff line OK?
SL11CKK Nov 25, 2012
  1. SL11CKK
    SL11CKK Active Member
    693
    35
    Just a quick one folks!
    I just realised couple of days that my cut-off line has 2 steps.
    I swear it should be just the one step; right?
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    Both lower lines should be level so the left is too high or the right is too low
    Don't try and correct them yourself take it to an mot place its far easier
  3. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,171
    150
    On flat ground, i'm sure the line should be same height as the bulb from 10meters.
    Something like that anyway.
  4. quattrojames
    14,050
    574
    Looks like the nearside light is set a bit high. The "line" of the lights should be the same height for both, and it will obviously kick up on the left for a lhd car.
    Their very simple to adjust, use the inner most adjuster (parked facing a wall as you are) and either raise the offside light, or lower the nearside one.
  5. SL11CKK
    693
    35
    Im going to do this hopefully tonight. Ill use the lines between the bricks as a rough guide then off to MOT to check if its within the range.
  6. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    my 1st view says your right side is too low and your left side is ok, get it to an mot place and get them to level them up for you,
  7. stu_m
    1,440
    Oh and make sure your headlight range adjuster is on 0 before they are set up
