Is it worth getting an uprated fuel pump?
NICK-C Sep 8, 2011
  1. NICK-C
    NICK-C Nick
    711
    114
    43
    Hi Guys,
    I have a remapped S3 and wonder is it worth getting an uprated fuel pump? I have heard that mid rev range an uprated fuel pump is much better? I thought these would be about £100 - £150 but after doing a quick search APR one is over £600!!! Am I looking at the correct thing? Where/who is best to get one from?
    Cheers.
  2. Cartéen
    Cartéen New Member
    9
    I think you already have a uprated fuel pump. I have heard from several people tha the facelift model (2009-) has a better pump.
    Can anyone confirm this?
  3. S3Alex
    10,827
    4,820
    For Stage2+,the uprated HPFP is still required,as far as any of the specs from Revo etc go.
  4. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    I agree with Alex - but you can get the internals for about £290 and then about £50 to fit and £50 for the next "dose" of software!
  5. GNJ_Motorsport
    GNJ_Motorsport Site Sponsor Site Sponsor
    660
    188
    43
    Were are people getting the uprated internals from? Just starting to look at options for stage 2+. Will be stage 2 in a couple of weeks.
  6. phil76
    phil76 Active Member
    572
    40
    If your going heavy on the map its worth it as any car running linear is when the damage gets done
  7. S3Alex
    10,827
    4,820
    Mine was the Autotech pump internals,supplied and fitted via AMD Essex.
    Some people get worried about internals only,but mine has given no problems at all over 30 000 miles,and as long as it's competently assembled in clean conditions,there is no reason why it should....be sure to change the cam follower regularly.
  8. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,473
    611
    The Autotech internals are around £360 brand new but some GB's bring them down to £300-310
    I paid full wack as I needed it pronto :( £360 from AMD and fitted it myself following the instructions provided.
    £60 to Revo to remap the car and job done!
    I have also purchased the RS4 fuel valve to eliminate top end flat spots which still has to be fitted to the car!
  9. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
  10. NICK-C
    NICK-C Nick
    711
    114
    43
    Hi Guys,
    Many thanks for the replies and it is probably not worth me getting then as I am only going stage one and I assume it won't make that much difference?
    Cheers,
    Nick
  11. Rob W8
    Rob W8 Member
    953
    I have go some Autotech HPFP internals for £320 Inc delivery via special delivery before 1pm.
  12. N8
    17,163
    718
    Answer is yes you will need them if you want more power!
  13. brough74
    brough74 Member
    423
    22
    You dont need one for stage 1
  14. S3Alex
    10,827
    4,820
    You won't need it for Stg 1 or Stg 2......it's only at Stg2+ that you will need the HPFP uprated.
  15. Paullie
    2,076
    288
    You don't need an HPFP for S1 or S2 as the maps for those stages don't demand anything outwith the safe parameters of the standard fuel pump, but from what I've read an uprated HPFP will produce gains even on a standard car.
    For anyone looking to buy Autotech HPFP internals, I cannot recommend Robert_Waite highly enough, ..fab price, lovely fella to do business with and Next Day delivery! :wub: x
  16. akash_sky1
    akash_sky1 Active Member
    1,181
    Paullie's exactly right there. Both Statller and Star Performance have the said the same to me. I felt an improvement after having the pump uprated, especially in the mid-range torque, even before the new software was added.
