Is it safe to have wheel spacers together??
seen_ Jan 9, 2010
  1. seen_
    seen_ Member
    40
    At the moment I have got 5mm wheel spacers on the front two wheels. But the inside of the tyres are still rubbing against the suspension twist nuts.
    I am thinking to add 3mm spacers to the 5mm spacers to equal 8mm, is this safe or not? the reason i don't want to buy 10mm wheel spacers is because i don't want the wheels to catch on the arch.
    The wheel nuts I am using are standard, i've heard if you get 3 or more turns on each nut its fine.
    Is it ok to have 2 or 3 long nuts and the rest standard or does this affect the wheel when turning?
    Sorry for all the question but I am in need on some guidance.
    Thanks in advance :)
  2. Mpathe
    Mpathe 1st gear
    394
    yes would be safe to use the 2 spacers together but as for the bolts i wouldnt risk the chance, for the sake of 25-50 quid its not worth it, to think how much damage it could do if 1 wheel comes off.
  3. PH1L
    PH1L Gievf Buckets
    3,851
    40
    as for the spacers you could always tack em together, by gas, mma, mig or tig welding em
  4. Ronburgandy
    Ronburgandy Taking it back OLD SKOOL
    15
    I would go for new bolts too mate,
    with all the questions asked from the Edition38 and Golf forum the general 'sensible' answer is you need to accomidate for what your changing, if you think you will nearly be taking 1cm from the bolt lenght and thats a bit worrying when you look at the length of the bolts
    You also need to think are they HUBCENTRIC spacers as the general weight of the wheel is on the centre bore of the hub where as the bolts are literally to hold the wheel on the centre bore!
    if your spacers arent HUBCENTRIC all the weight is on the bolts and you will def be asking for probs!
    Is the ET on your wheels really high?
    Ad
  5. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    From an engineering point of view.....one spacer will ALWAYS be better than 2 stuck next to each other.
    Now sorry for sounding harsh...BUT
    Lashing 2 sets together and tacking them IMO is bloody stupid unless you know what you are doing and you can get them TOTALLY lined up and straight. Doing them by eye isnt good enough. You have to make sure you get them in line and butted up correctly, tacking them together...I wouldnt.
    As for only using 2 long bolts, why oh why would you do that??. For the sake of the extra cash just buy a full set of bolts!!.
    How the wheels attach to you car is quite important, if one falls off then you're in the sh*t so you should make sure that if you're doing anything wheel related you DONT cut corners and do it properly.
    I'd enquire about getting some spacers made rather than using 2 sets.
    T
  6. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Mine aren't hubcentric n I haven't had any probs, they've been on for quite a while. I am using 12.9 grade bolts though. When I have money, I will evetually get some hubcentric ones, it's just the 20mm hubcentric spacers are quite pricey.
    I do advise you to get longer bolts like all the others are saying.
  7. sportquattro
    sportquattro Active Member
    834
    51
    I imagine your insurers would have something to say if a wheel came off due to you not using longer bolts, there's an old saying,"if in doubt, there is no doubt" and IMHO the very notion of using too short a bolt to hold your wheels on is just asking for trouble. In other words I'd get the right spacer and the right bolts, anything less is dangerous and irresponsible. Sorry if that sounds harsh.
  8. seen_
    seen_ Member
    40
    Hey guys...thanks for your responce!!! :)
    You lot are right...will probs get new spacers and longer bolts! will probs try and get hubcentric ones but can't find any that are 8mm-10mm.
    Btw if i wanted to get spacers made where could i get them done from?
  9. S3Steve
    S3Steve Active Member
    1,609
    17
  10. <tuffty/>
    20,873
    3,698
    Generally speaking you won't get hubcentric on anything less than 15mm spacers as the chamfer to the spigot will be too thin... that said I do have hubcentric 10mm spacers but they will only fit certain wheels like OEM for instance as aftermarket wheels differ on the chamfer from the mounting face to the hole in the middle.
    While H&R spacers may well do hubcentric 8mm spacers, they may not allow your particular wheel to mount flat on the hub/disk which is...... bad.....
  11. seen_
    seen_ Member
    40
    my wheels are rs4 replicas so they must be aftermarket
    so my best bet i guess is 8mm normal spacers and longer bolts?
  12. A3Tom
    3,504
    14
    Yep, you got it.
  13. jojo
    28,845
    3,503
    Wouldn't this effect the balancing of the spacer?
  14. DPM
    DPM Site Sponsor Site Sponsor
    4,962
    193
    Personally I'd say get 8mm spacers and don't use 5mm + 3mm and always get the correct length bolts.
    Damian @ DPM Performance
  15. badger5
    9,398
    1,942
    get 10mm hubcentric.. so you have a hub to hold the wheel..
    if you use plain flat or stacked spacers like you are, you have little or no hub engagement in your wheel, allowing for the chamfer lead in the wheel itself.
    longer bolts mandatory.. and no 3 turns is not sufficient.. 3 x 1.5 pitch is only engaged 4.5mm on an M14 bolt.. Unsafe what you are currently doing
  16. <tuffty/>
    20,873
    3,698
    ...not to mention potential for heat distortion upsetting the flat mating surfaces...
  17. seen_
    seen_ Member
    40
    thnx evry1! :)
    just curious?!? has anybody just got spacers at the front of the car and none at the back? or is it best to have spacers on all wheels? because my rear wheels are fine! just need to get my front wheels away from my suspension slightly!
  18. A3Tom
    3,504
    14
    I dont have any on mine :)
