is it normal for an a3 to sound like a scooby?
tyson Jun 27, 2010
  1. tyson
    tyson Member
    136
    i have an audi a3 1.8t quattro i have fitted a carbon airfilter today and now in the lower rev range it sounds like a subaru rather than a normal induction roar, is this normal or is something wrong with my car?
    any help would be appreciated
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,231
    2,051
  3. MURRAYS444
    MURRAYS444 Member
    790
    When you install an induction kit it will change the noise of air flowing into the engine as there is more air getting to it I think I installed an induction kit on a clio and the noise changed a lot and have fitted a k&n panel filter to my s3 and the is a small difference on induction noise anyway your car must sound pretty good if you ask me!!!
  4. Chlippo
    Chlippo Member
    679
    15
    u said it mate:
    "i have fitted a carbon airfilter"
    Sure this does change how the car sounds. Im pretty sure nothing wrong with your car, but if you are that worried, well get that filter off and re-install the factory filter and see if it will sounds how it used to sound
  5. Matt82
    Matt82 Active Member
    2,365
    i think the only way youd get a 20vt sounding as stupid as a scooby would be if the 20vt was running on 3 cylinders
    is the idle really lumpy?
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Yep, my first thought. Misfire.
  7. Matt82
    2,365
    thats cos youre my brother from a different mother
  8. Welly
    10,696
    129
    :thumbsup:
  9. tyson
    tyson Member
    136
    it did seem a bit restrictive in the higher rpm range. and bogs a little off the line now. it sounds good but ive fitted induction kits to other cars and it never sounded like this, as soon as you get above 2000-2500 rpm the noise stops and turns into a normal induction sound?
  10. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    what carbon filter is it? does it have a brand?
    my carbonio has a loudsucking sound and then a whoosh which can only be described to sound like darth vader
  11. tyson
    tyson Member
    136
    hi its not a branded one, when at low rpm when the power bogs it makes a burbling noise like a subaru exhaust makes, then in the midrange it sounds normal, and im sure it seems gutless in the higher rpm range as though its running out of power
  12. Jay
    Jay Member
    318
    I fitted a simota filter a few weeks back and mines sounds the same below 2500 rpms then sounds different when on boost. pretty sure its fine. No errors logged or any driving problems experienced. Seems to do it more on cold starts.
  13. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    An A3/S3 will never sound like a Scooby lol.
  14. Matt82
    2,365
    take out a spark plug, or two and youll be close (and obv put on a proper big boy exhaust with comedy dv) and youll be close
    scooby = sounds like its broken
  15. Welly
    10,696
    129
    Ummmm, no, I'm pretty sure that it's NOT fine.
    How on earth is your car not running properly ever going to be fine? The OP is claiming that the A3 he's driving sounds like a Scooby - meaning running on 3. I've heard it myself when I've had coils go.
    Misfires mean one of two things in this scenario. Too much fuel, or too much air. Too much fuel will cost you a bomb over a long period of time, and too much air is even worse, as will cause detonation and things like holes in pistons.
    If it was OK before, and you've fitted this induction kit and now it's running like a bag of nails, something is VERY wrong.
    Firstly, remove the bloody thing and put the air box back on. See how it runs then. If OK, then throw the induction kit in the bin.
    Alot of these no name brand induction kits have a ludicrously small air filter element inside the casing, which is VERY restrictive to the engine. Air flow through a turbo engine is one thing you do not want to restrict. N/A cars it doesn't matter so much, but when the turbo is pulling air through the filter at (Based on your car if standard- 1.8 TQS 180 BHP) 144 G/S, you need something to accomodate that air flow, not make it as hard as possible for it to get through.
    My advice is remove the thing and retest to make sure it is OK then. If so, invest in a good, free flowing induction kit, otherwise there will be potentially disastrous consequences.
    You have been warned.
  16. 5teve L
    5teve L Member
    152
    I take it A3 has a MAF like the S3 ? Have you unplugged it ??
  17. tyson
    tyson Member
    136
    no ive attached the air filter on the end of the MAF. im not too sure but the car still feels about the same in midrange but it does feel restrictive now in the higher rpm range, don't really want to damage the engine so was going to take it off and was thinkin of putting a carbonio CAI on? if its a good idea does anyone know where to get one cheap?
  18. Chlippo
    Chlippo Member
    679
    15
    carbonio and cheap are two words that you cant use in the same sentence mate
  19. Welly
    10,696
    129
    Agreed, but not cheap, because they aren't *****.
    Buy cheap, buy twice.
  20. Matt82
    2,365
    but before you go anywhere... what are you actually planning to gain with a new airfilter? i higly doubt itll be power
  21. DaveA3
    2,370
    15
    worth keeping an eye on ebay and the ukmkiv's forum etc edition 38 perhaps or even the seat cupra forums.
    might get one on there for half retail price.
    the sound is like no other but the price is nut for that. depends how much u want the sound lol
  22. tyson
    tyson Member
    136
    so a mk iv golf carbonio kit will fit a a3?, ive got a REVO remap and forge dump valve and the guy said to get a free flowing airfilter and exhaust then i can have the stage 2 remap thats why i've got the airfilter.
  23. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Carbonio's aren't **** though, plenty of Mk4 Golf 1.8T's use them. You need to put the car on vag-com ideally to see if there's a problem with the car. As mentioned above, sounds like a wack coilpack.
  24. tyson
    tyson Member
    136
    don't you have to buy the vag-com software? and a cable? or is there somewhere i can go ?
  25. ALPINE
    3,093
    oh no, the "cone filters are ****" debate again!
    And Scoobys sound sexual btw! flat 4 sound Awsome when tuned!
  26. ALPINE
    3,093
    tyson, can get a vag com lead on ebay for about a tenner, or you can get the full software off of NHN on here. As for a cone filter etc, as long as you protect them from heat soak there fine. i proved gains via Vag com using a kit i developed for the 1.8t, walked over the OEM box all doy long. Alot of non OEM haters on here. :p
  27. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    Simply, yes. Its normal.
    If you mean especially at full throttle at low RPM then it does sound like a scooby a bit.
    As long as the power is smooth, then its fine.
  28. tyson
    tyson Member
    136
    thats exactly how it is at low revs when throttle is fully open. in that case i might keep this filter on for a while thanks RichA3Turbo
  29. emery1990
    emery1990 Active Member
    1,068
    have you swapped it back to the airbox yet then? It shouldnt gurgle, just take it off and put the standard one back on. turbo looses puff after around 5500rpm so thats why it tails off then.
  30. tyson
    tyson Member
    136
    its as RichA3Turbo said it only makes the scooby noise when throttle is fully open at low rpm...to be honest there wasn't any difference between the airbox and filter i just like the noise it makes.
  31. emery1990
    1,068
    Id get something decent on there though if people are saying they can restrict flow. you was saying it felt flat etc lol
  32. FumaS3
    FumaS3 Member
    i resently added a powertec induction kit to my s3 and my friend added a k&n to his 1.8t both are cone filters. the sound you getting is normal imo in low revs you get a scooby esk ruble but its short lived as asoon ans you give it any beans the noise of the induction roar and turbo drown it out i find if you finding it flat you may have some other underline issue as giving the car more air should mean more power also might depend on the state of your exaust have you checked that
  33. tyson
    tyson Member
    136
    i put the standard airbox back on and drilled a hole near the front to snuggly fit a pipercross cold air feed from the front bumper, it seems better than the induction kit so il leave it as airbox for now, the exhaust looks in pretty good condition.
  34. Welly
    10,696
    129
    Let me guess, the misfire has gone?
  35. S3-Andy
    S3-Andy Member
    204
    sorry to change topic what wheels are they mate??
  36. nicko86
    nicko86 nicko86
    31
    take it off, see what its like without it!! simple break-downs explain a lot. if the filter has no manufacture or name id be a little worried with universal filters doing more damage than good. might be acceptable for a first car with a crappy 1.1!
  37. nicko86
    nicko86 nicko86
    31
    **** sorry didnt read all the blogs! you've blatently done this already!!! i feel small!
