Is it my wastegate I can hear
JamesA3 Mar 23, 2004
  1. JamesA3
    JamesA3 Member
    238
    when I lift of the throttle I can hear a very quite woosh noise which I have heard on other cars and was told its the wastegate is this correct?
  2. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Its the DV when you let off the throttle pedal
  3. JamesA3
    JamesA3 Member
    238
    thats what it sounds like but I haven't fitted a DV, do they come as standard on 1.8T's
  4. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    All turbo cars have DVs!
  5. JamesA3
    JamesA3 Member
    238
    are they recirculating then rather than atmospheric?
  6. tennisguy
    tennisguy Member
    82
    Yes it is recirculate. If it is atmospheric (some of them are from aftermarket), then your car will lose power.
  7. Grant
    1,206
    118
    Audi's have recirculating valves. DV in this case meaning Diverter Valve rather than Dump Valve.
    A couple of people on here are running asmospheric dump valves although it has been argued that it is not good for the car and therefore not recommended!
  8. Mike.M
    2,510
    170
    I only went to use "Mobil 1" engine oil as it was recommended by Forge to service their DV's.
    Will get some of the grease you guys mentioned and give that a try at the weekend...................cheers!
  9. Gambba
    Gambba Active Member
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    Mike, the actual service instructions from Forge specify Mobil 1 Grease, which is either a typo by them or there is actually a Mobil 1 grease, but I don't know of one without looking on the web.
    /ubbthreads/images/graemlins/beerchug.gif
  10. simont
    simont Member
    116
    on my old S3, you could hear the air being released by the DV back into the airbox a lot more than the standard S3...
    This was due to when the garage replaced my wing and them not doing a proper job by refitting the sound proofing on the inner wing! /ubbthreads/images/graemlins/mad.gif
  11. TheTonsta
    TheTonsta Member
    95
    Guys
    Had a look on the Mobil 1 site - indeed they do do a Mobil 1 Synthetic Universal Grease..
    [ QUOTE ]
    "....All Mobil 1 products, just like Mobil 1 motor oil, protect hardworking parts from temperature extremes, rust and wear. In fact, the same synthetic technology found in our motor oil is used in our fully synthetic grease.
    Mobil 1 Synthetic Universal Grease provides excellent protection against rust, corrosion and water washout. It's suited for wheel bearings, ball joint suspensions, steering linkages, and king pin and chassis lube points.
    Benefits:
    Excellent resistance to rust and corrosion.
    Good shock-loading protection.
    Excellent resistance to water washout.
    Outstanding lubrication over a wide temperature range.
    Applications: Recommended for automotive applications at both high and low temperatures. It will provide outstanding protection where moisture or condensation are factors...."
    [/ QUOTE ]
    Here's a link to the Product Data Sheet for Mobil 1 Grease
    Tone /ubbthreads/images/graemlins/beerchug.gif
  12. Drill
    Drill Member
    928
    Tone, thx for looking Dude /ubbthreads/images/graemlins/grin.gif
  13. Gambba
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    Saved me a job /ubbthreads/images/graemlins/beerchug.gif
  14. PaulRS3
    PaulRS3 Well-Known Member
    1,218
    150
    WAK on the TT forums has some of this Mobil 1 grease in tubes for sale.
    NOT cheap mind you. He could only source it from US and got stung by vat/customs.
