Is it boost tube?
kachnak Dec 5, 2009
  1. kachnak
    kachnak Active Member
    119
    45
    Hello, today I found some tube which is going from motor space to interier. See two attached photos.
    Is this tube for boost gauge?
    Thank you
    (wait a minute please i can not find here button for add photos from my computer)
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Looks to be, that's what I would guess at least. Looks like the generic tube that come with most boost gauge kits...
    It it blocked off? If not that's a nasty little boost/vac leak.
  3. kachnak
    119
    45
    The end of this tube is no blocked. It is like on photo. when i put there finger I feel little vacuum. It was same vacuum if motor runs in 1000 or 6000 rpm.
    I think when motor runs faster there must be some pressure no vacuum or not?
    During driving sometimes I hear some sound like tssssssss
  4. Prawn
    11,370
    3,234
    revving the engine stationary will not see you any boost still, as there is no load, so you'll still see a vacuum. try plugging it and see if it makes any difference, or install a guage on it!
  5. Welly
    10,696
    127
    Yep, either block it off of use it for a gauge...
    Even a pipe that size will lose you a substantial amount of boost, so it defiantly needs addressing as soon as.
    That is definitely what the noises you're hearing are.... Just find a screw and wind it into the end of the pipe, bit of silicone around it, job done. :)
  6. pauldazzle
    pauldazzle Well-Known Member
    1,122
    80
    Yeah it's definitley for a boost gauge, you need to plug it asap or put a guage on it.
