Is a liquid gauge as good as a standard boost gauge?
S3 JOHN Jun 9, 2012
  1. S3 JOHN
    S3 JOHN Member
    310
    Hi all,
    Been looking into this for a while and haven't really found an answer yet ? And also been looking at standard gauges and in the photos i see standard and liquids in the same car making be believe that the liquid is not accurate?
    Any help would be great.
    Many thanks
  2. <tuffty/>
    20,847
    3,687
    Have you read the review I did in the stickies?
    Liquid shows boost in 2 modes... first one reads from the MAP sensor (on engine codes that have them) and shows the same boost as the ECU will be seeing, the second is AGU mode where it calculates the boost base on a similar algorythem as the AGU ECU does to work out boost...
    MAP sensor mode is limited to the MAP sensor 1.5bar max... so will only report 22psi max and no vacuum
    AGU mode shows up to 30psi (iirc) and will show vacuum... not compared this on the dyno yet but will do if I think about it.. mine reads a bit differently to my boost gauge too
    That said... without calibrating the boost gauge there is no real way to compare... all you can be sure off is in MAP mode you will see what the ECU sees and what it uses to regulate boost
  3. S3 JOHN
    S3 JOHN Member
    310
    No i didn't , where do i find this and il have a read?
    Right ok i understand 95% of that as i am not totally clued up on all this yet but slowly learning. What is AGU mode ?
    Im really interested in getting the liquid as i like the idea of being able to scan for faults and the other features included in this bit of kit .
    Would you recommend buying one on you experience with one ?
    Many thanks
  4. <tuffty/>
    20,847
    3,687
    The stickies/FAQ link at the top of the 8L section...
    http://www.audi-sport.net/vb/a3-s3-...info-stickies-please-read-before-posting.html
    I run a boost gauge and a Liquid gauge... personally I prefer the boost gauge for boost... its just better... I use the liquid in multi gauge most of the time but use it for EGTs or AFR mainly...
    As for fault codes... you should be aware that Liquid will only scan the ECU... it won't scan other modules around the car... VCDS is a better bet...
    If you have limited funds, buy a decent boost gauge and VCDS... if money isn't an issue then buy a decent boost gauge, VCDS and Liquid in that order
  5. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    195
    Yeh come on tuffty share! I wann know this too....... I like the look but £250 cash pound notes is not cheap!
  6. s33nyboy12
    1,484
    195
    Ok you posted that before I had done eating my twirl, thanks lol! And I would get normal boost gauge anyway as prefer these! I do like look of liquid in vent though.
  7. <tuffty/>
    20,847
    3,687
    The stickies are at the top of the section... nobody ever reads them :(
  8. S3 JOHN
    S3 JOHN Member
    310
    Cool! thanks for the info Tuffty . And as from now i will look at the stickies . Just one last question where is the best place to but VCDS from as i here the ebay jobbies are not much good ?
    Many thanks
  9. <tuffty/>
    20,847
    3,687
    Look in the stickies of the VCDS forum here on ASN... ;P
  10. S3 JOHN
    S3 JOHN Member
    310
    Oh dear that wasn't a very good start on reading the stickies was it :undwech:im off to read !
  11. <tuffty/>
    20,847
    3,687
    Most if not all the sub forums/sections have stickies sat up the top... :)
  12. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    I am often in the stickies...I always read them before upgrading certain parts.
    Also helped me post pics so I could create an avatar :)
    I think a gague will be one of my last mods
  13. s33nyboy12
    1,484
    195
    A gague.......... What about a gauge ? Is that on your list? Lol
