Is 225/40/18 front and 235/40/18 back OK?
pengjn Jul 25, 2010
  1. pengjn
    pengjn Member
    81
    I bought a set of OEM RS6 alloys from ebay, had them refurbed and they are now mint. Only snag is that they are 225/40/18 on the front and 235/40/18 on the back. Before I jump in and buy the rubber, can anyone tell me if they are going to fit my car properly and if I'm going to have any issues with them?
    PS I'm planning on fitting Eibach springs to lower it to the same height as an S-Line, so not sure if this will make any odds?
    :think:
  2. akash_sky1
    akash_sky1 Active Member
    1,181
    Since your is a 2wd it won't matter if the rolling radius is slightly bigger at the back then the front, but the rear tyres may rub I think if you slam it, a 30 mm would be ok though I would have though.
  3. sub39h
    sub39h Active Member
    2,502
    are you sure they had the right rubber on 'em? if they're OEM A3 RS6s shouldn't they be 225/40 R18 all around?
  4. ghouseman
    ghouseman Gazza
    92
    thought rs6 had 19s
  5. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    they are both 40 profile and this will have no affect between the rolling radius of the tyres.
  6. dinsdale66
    dinsdale66 New Member
    Not true. the "40" is a ratio of the tyre width to sidewall height. 235/40R18 is a bigger diameter and circumference than 225/40R18.
    http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx
  7. pengjn
    pengjn Member
    81
    Bit confused now but that is partly due to big night out last night. I thought the 225-235 bit was just the width?
  8. lincoln_dj
    lincoln_dj Active Member VCDS Map User
    471
    61
    it is, the width in mm. but the 40 part means the "thickness" of the tyre is 40% of 225mm (ie 90mm, or 94mm if 235mm wide)
    would assume this could cause wheel speed sensor fault? certainly on 4wd cars...
  9. akash_sky1
    1,181
    His car's 2wd and hes running the larger rolling radius on the back so it shouldnt cause problems with that.
  10. v1raj
    v1raj Member
    306
    20
    I'm currently running this profile tyre setup on a set of Rossos.
    No problems at all mate, go for it :o.k:
  11. pengjn
    pengjn Member
    81
    Thanks v much everyone - good to know I have screwed up totally. Can't wait to get the new wheels on there - I've lived for far too long with the 17" Stars.
  12. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    I learn something new everyday! thats also a usefull link thanks.
