Irratic Idle - MAP sensor?
StanboA3 Jul 21, 2005
  1. StanboA3
    StanboA3 New Member
    13
    Hi peeps, i've started to notice some irratic idle speeds and every now and then the engine stalls itself (generally when pulling up to the lights etc). Could it be a faulty MAP sesor? If so, are they easy enough to swap out?
    Cheers in advance,
    Ben
  2. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    Ben,
    Sounds like an interesting problem, it might be worth getting it checked by someone with a VAG cable as they would be able to tell you exactly whats wrong.
    Regarding the MAP sensor - did you mean MAF? - if so, you can clean it first to see if that solves the problem.
    I'm sure it's been covered somewhere on her before, might be worth doing a search
  3. StanboA3
    StanboA3 New Member
    13
    Ok MikeA3, thanks for your help. Afetr posting I found out its a MAFI have not a MAP. I'll give it a clean, cheers
    Ben
  4. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    Could also be the throttle body actuator. It controls the idle and sometimes when its warn (like mine) it goes back and forth and finally settles...however, it does sometimes stall if you take your foot off too early. I just keep the revs up a bit with my foot and gradually bring it down to idle. A new TB is £190+vat for a cable throttle model.
    RIch
  5. Ryanc
    Ryanc Active Member
    1,321
    My Throttle Body ceased/stuck and idle was all over the place when it went wrong.
    A DBW Throttle body is £300+vat from the stealers.
  6. darnich
    darnich Member
    106
    You can always try and clean the throttle body with carb cleaner but you then have to perform throttle body calibration...
    Had a similar problem and my mechanic performed the above procedure...TB was foul of oil debry,
    ever since cleaning it I never had idle or stalling problems so far
    Hope that helps
