  1. marlowA3
    marlowA3 Member
    93
    Hi I got a 2005 a3 2.0tdi want to run my iPod in the car what do I need its just a audi concert standard cdplayer
  2. andrewguk
    andrewguk New Member
    26
  3. marlowA3
    marlowA3 Member
    93
    Ill have to take a buy i think, is it easy to get the standard sterio out to plug the cable in?
  4. slappy
    slappy Member
    205
    Yes it is.
  5. Paddymph
    Paddymph Member
    70
  6. slappy
    slappy Member
    205
    It's cheaper because you have to physically handle your ipod to change tracks etc whereas the Dension ones charges your ipod and allows you to control the track changing via the headunit.
  7. Paddymph
    Paddymph Member
    70
    But it'd still work?
  8. slappy
    slappy Member
    205
    Yes it will.
  9. schmergal
    schmergal Member
    114
    is it just your ipod or iphone music folder you can control or music apps also
  10. weela89
    weela89 Member
    64
    Right,
    So am i right in saying that all standard concert stereos (mine is an Audi a3 2007 2.0tdi) have an auxilary input to facilitate an audio cable? Its just a matter of pulling the head unit out and installing?
    Cheers,
    Matt
  11. slappy
    slappy Member
    205
    No, if you read the above posts, you will need to do exactly the same thing as MarlowA3, you need an aux adaptor (like the Connects2 interfaces).
  12. Paddymph
    Paddymph Member
    70
  13. Quattro180
    Quattro180 Member
    99
    I recently purchased the dension lite for my concert 2 head unit but it says "NO CDC"? Has anyone else had this or am i doing something wrong?
    cheers
  14. Paddymph
    Paddymph Member
    70
  15. slappy
    slappy Member
    205
  16. slappy
    slappy Member
    205
    Have you earthed/grounded the Dension Lite?
  17. Paddymph
    Paddymph Member
    70
    Top man! Now where to stick the red wire?! I really am an Amatuer at car hifi I apologise ...!
  18. slappy
    slappy Member
    205
    That needs to be wired into a switched/ignition live (in the fuse box) as otherwise your ipod may drain your car battery unless if unplug it after getting out of the car.
  19. Paddymph
    Paddymph Member
    70
    Ah balls i'm clearly out of my depth! The wire is like 5 inches long only?! I'll have to wire that From behind the radio to the fuse box? Feck.
    And it's my iPhone so will be taken out each time. Thing is, if I just plugged the blue plug in and grounded (like i tried) would it just work?
  20. Paddymph
    Paddymph Member
    70
  21. iamwhatiammomo
    iamwhatiammomo Member
    170
    I have the dension 100 brilliant piece of kit, supports iPod connection and aux.. Been told the xcarlink is just as good but a lot cheaper.. Plug and play
  22. slappy
    slappy Member
    205
    Possibly, it's hard to tell. Worst case scenario is that you get an error on your headunit displaying NO CDC.
    To be honest, for a few quid more, you can get a second hand dension unit from ebay and they are pretty much plug and play.
  23. Paddymph
    Paddymph Member
    70
    Yep... I hear you! Thanks for the help!
