IPOD conection and Symphony 6 disc head unit
Topless in the Summer Mar 9, 2011
  1. Topless in the Summer
    Topless in the Summer New Member
    Hi,
    I have a 58 plate A4 cab, It has a glove box Ipod dock. When I plug in an I phone 4 or nano g3 nothing happens, and I can't see an "i Pod" input button on the symphony head unit.
    Any ideas?
    It's going back to the dealer tomorrow for the No plate lights, v common I understand and a faulty speed control on the wipers stalk :(
  2. redspudder
    redspudder Sparky
    371
    I have AMI in the glove box and have my ipod touch plugged in but have also used nano in there,if you press the media button on the stereo it should play either SD card,Ipod or CD.Once you select media button then press the source button (top right button of the 4 on the stereo,if you look on the display it tells you which button does what on the stereo) this then allows you to select which option you want to play.
    Hope this helps
  3. hades-
    9,481
    646
    are you sure you have a B8 cab ?
    i recon its a B7 cab
  4. redspudder
    redspudder Sparky
    371
    Bez
    you would be correct it will be a B7,not sure if the stereo set up is the same??I would guess the unit will be the same as the B7 saloon and avant
