iPod and radio signal faults
s3_kev Oct 9, 2013
  1. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    Hi guys I've only had my 8p s3 for a couple of weeks now and there's a few bits bugging me on the stereo side of things, 1st off is the radio signal being poor I've done some searching on this and reckon it might be the antenna at the rear screen, however I want to upgrade to RNS-E once funds allow so I really don't want to be changing the antenna yet as there be swapped over come the headunit change? mine's currently just a concert item. But is there any known fixes that I've not come across as of yet? or any other ideas as to where the problem may lie?
    My other issue is that my iPod plugs in and plays fine when I 1st start the car but once I move off and go around 10mph and the doors self lock most the time but not always the iPod will stop playing through the stereo and I have to unplug it and reconnect (sometimes a few times) and it comes back on, could this be linked with the door looking? or is there a fault with my stereo? I've not got another iPod to try or atleast not yet tried another iPod. Another thing possibly related after doing a little research is that the iPod should be getting charged whilst plugged into the car? mine says that charging is not supported on the iPod screen.
    cheers guys
  2. NHN
    29,596
    1,782
    What year S3?
  3. s3_kev
    2,002
    23
    2007 "57"
  4. NHN
    29,596
    1,782
    Depends on how much it bothers you, as if you're going to invest in rns, which given your year requires antenna upgrade to have optimal reception, I would save the money & use for the upgrades instead of fixing current setup.
    Check the rear screen elements for any damage & inside bootlid for signs of water damage.
  5. s3_kev
    2,002
    23
    Yeah I'd leave the radio signal issue until the upgrade (be early next year) I did notice yesterday that one of the rear screen elements has a break in it, I've ordered some of the repair paint kit you can get hopefully that will arrive tomorrow.
    Would the upgrade likely cure the iPod fault if it's the car at fault? I've still yet to check with another iPod if I still get the same fault
    cheers
  6. NHN
    29,596
    1,782
    Ipod charging issues will more than likely be down to the change in charging pins, adapters are usually the cure for this.
    If there is an element broken, then yes this could cause the issue.
    s3_kev likes this.
  7. s3_kev
    2,002
    23
    I've got an extension cable I use so the iPod can still be handled without being wedged into the glove box, I reckon the fault will be down to my iPod.. I will just get a spare iPod to try for this as there's not a common fault
    cheers again, hope to see you in the new year
