Ipod and Dension help
JLA Oct 12, 2008
  1. JLA
    JLA Member
    101
    I bought a Dension Icelink off ebay, went to instal it thinking it would be a straight forward job only to find there are 3 or 4 plugs on the back of my head unit. Which one do I need to unplug to fit into the Dension adaptor part? Also I read on here that you need to download something from Dension onto your itunes so that it can program the interface. It came from an Audi so will I still have to do this and if so where can I find said file? Densions website is a bit ****!
    After trying to find the info I need on here, I'm starting to wonder whether this icelink is really worth it, it sounds complicated to use and its going in my missus's car (women and technology)
  2. recomdos
    recomdos Active Member
    1,006
    The Dension link replaces the 6 disc multichanger. If I remember correctly that is the blue block in the back of your stereo. You do need to download a track and run that as a config file - I think you need a couple, one to clear the ipod and prep it, the next to assign it to Audi. Not sure if yours will run already. Let me know if you're struggling I think I have mine somewhere.
    Sometimes you can experience problems with the icelink. Such as it not letting the headunit control it - a bit like a pc crashing. Though overall I definitely think it's worth it. I often put mine onto shuffle and just jog through tracks.
    Hope this helps.
    Rob
  3. herbie
    herbie Member
    107
  4. GT130
    GT130 Member
    247
    I'm in this position at the moment, just got an i-pod and the wife will buy me a connector for xmas, from what i can understand the advantage of the denison is you can set the play lists on the i-pod via pc and go through them using the head unit 1-6 selector - i've got the 6 disc in dash which i guess has a cd changer in at the back to connect with but how do you select the cd changer (i-pod) option on the stereo - can't see a button for cd changer/aux....
    Couple of questions pls :
    Is the Denison significantly better sound quality then just a tape convertor?
    Whats the x-link option - how much compared to the denison 100 quid option (for just a lead/interface!!)
    How do you select the changer option on the head unit
    Does the in dash 6 cd audi unit have an aux in on the back via rca type connectors?
  5. Vag_Geek
    Vag_Geek New Member
    12
    I had the same dilema today! Instead i got an Alpine head unit with full iPod connection and control for £180 fitted at Chorley Car Audio (Lancs)
    Spot on job as well.!
    Hope this helps,
    Geek!
  6. I can only answer a few of these questions:
    Definately, and far better than an FM transmitter too. To me it seems as good as a CD, although it does also depend on the quality of your MP3 files too.
    On my Symphony head unit I have a CDC button (CD Changer I guess).
    The user manual should say?
    I've been using a generation 4 ipod with my Denison IceLink Plus which has worked really well, and will never not have one again.
    I got a new Ipod Touch recently and unfortunately the generation 2 ipod touch doesn't charge. It because apple have changed the input voltage or something, so old usb leads etc won't charge either. It just worth checking before buying a Denison that it will actually charge your ipod - like I say though, it only seems to be the latest ipods that have this different charge situation, and I don't know if Denisons latest product accomodate this.
    The Denison website is rubbish. It doesn't help that the company called DenisonUSA who I think were the main distributor in the US appear to have gone bust. All of my searching on forums etc had links to this site which seemed to have loads of useful stuff thats not there anymore.
    Having said that, I emailed Denison support recently via their website and the service was amazing - they responded straight away and were really helpful. My advice would be to not waste too much time looking around the web, just contact them.
  7. peakey
    peakey Member
    263
    dose your bose sub work with it ???
  8. 1animal1
    9,978
    hmmmm this is really useful, although how would the Denison work with a Symphony 2 HU which as we all know has a built in changer......
  9. danotto
    danotto VAG HUNTER
    1,090
    i use dension icelink plus in my s3 which has bose,it makes the stereo sond better as well,i still havent got it to charge my ipod through the car battery though:(
  10. 1animal1
    9,978
    Dan is your a double DIN unit with built in changer or single DIN
  11. danotto
    danotto VAG HUNTER
    1,090
    dunno mate im rubbish with stereos cant remember i fitted it about 12months ago i unplugged the cd changer lead and fitted the dension lead,thats all i can remember,sorry mate
  12. 1animal1
    9,978
    no probs fella.....incidently single DIN is same size stereo as normal stereo, double DIN is the double size....ie the S£ without the cubby hole in the dash
  13. GT130
    GT130 Member
    247
    Thats what I need to know, I have the double DIN size with built in 6 disc changer, cant see a button for an additional changer but have yet to take the unit out to see the back of it..
    Can you use the Denison and I've got an i-pod mini generation 2 - that should charge then, had a look on the site and it's compatible so I guess it will charge on the move...
    Think I'm sold on the idea of the Denison due to quality of sound and play list selection - just like confirmation it will work with my 6 disc in dash from a 51 plate S3 and that there is no other easy (and good quality sound option) like RCA in's on the back....
  14. Shy19s
    Shy19s Oil running through my veins.
    886
    I may be mistaken in thinking this, but isnt this just like an FM transmitter except it wires in via the arial direct instead of changing the sound signal to a radio signal? Abit better but never going to be as good as a direct link?
    Dont you need a Smart lead so your back speakers work? on most audi's as the rear speakers are amplified you need a smart lead so it amplifys the back speakers as well when you use an auxillary input.
    There are converters that you can buy if you dont mind loosing the CD changer, they use the same connection and is a better quality sound however you loose the connection..
    Id reccomend the IO play.. bluetooth connection.. best link for ipod without changing the stereo and you can use your phone with it too.
    small dongle connects to the bottom of any ipod, and transmitts it via bluetooth, perfect quality and you can use your ipod as normal.. only downside is that you cant charge it while in the car, but can do that at home, and you get handsfree calling for the same price and quality of a parrot kit for example.
  15. 1animal1
    9,978
    GT i dont think we're gonna get the answer we're after mate, we cant disconnect the disc changer shy as the disc changer is integrated in our HU's..... for those of us with double DIN units.....
    im gonna be buying an ipod soon but only on the condition that i can rig it up for use in the car....... i already have aparrot bluetooth so hard wired is preferred
  16. danotto
    danotto VAG HUNTER
    1,090
    oh my cd player has a cubby hole beneath it so must be single din
  17. Shy19s
    886
    animal get in touch with parrot see if you can get an integration dongle like the io play that will alloy you to play your ipod through your speakers via bluetooth? By now im sure they have like a lead or something you can wire in behind your dash, then connect something to the ipod.
  18. 1animal1
    9,978
    gonna nip on the website mate, last look revealed nothing earlier in the year unless you bought their HU with integrated coffee machine etc...looks pants though, plus this car needs to remain OEM IMO
    Cheers for the suggestion fella
  19. Shy19s
    886
    Animal, what year is your car.. what model did they release the double din units?
    There is a kenwood double din, dvd, sat nav bluetooth unit i want to fit into my car but obviously dont have the space.. maybe if i can find a center consol from a car like yours i can fit it..
  20. 1animal1
    9,978
    i think they came out on facelifts mate, not the easiest of jobs from what i understand changing the dash as you have to replace the whole centre and the gear stick back to the rear seats..... obviously the climate will be different, id hope these were the same plugs etc....
    things arent all doom and gloom....you'd have a nice cup holder after all that graft :icon_thumright:
  21. S£
    S£ Member
    684
    The sym ii still has the cd changer port on the back and it can still be used, the adapter you get that plugs into the cd has a socket for the changer on it too so you could have the hu 6 disc 6 disc in the boot and the ipod if need be!..... The ipod is selected by pressing the cd button twice. The lead is then run into the glove box where your ipod will stay, the cd + , - buttons do the play lists and the track are done by the normal track change buttons you can only have 6 playlists though with 99 tracks per playlist. This way is so much better than bluetooth and fm transmitters it's not even worth considering them.
  22. Shy19s
    886
    glad you got your answer dude... Animal shouldn't be to much of a hard job already changed all of the interior including the entire dash board carpet seats an door cards, so the center consol would be least of my worries as long as I can fit that stereo, it's awesome. Thanks for your help tho.
  23. GT130
    GT130 Member
    247
    Thanks mate - I know what I'm getting from my wife for xmas then !
    They seem to be 80 quid on line - let me know if anyone knows of a cheaper source.
  24. 1animal1
    9,978
    ok, i contacted a UK supplier who has said that Dension have upgraded the new leads to work with latest gen Nano's.... anyone any experiance of this? i have decided i am going to be purchasing a new Nano:whistle2::) and so want to fit a denison so that im set to go.....
    weird as i never thought id want an ipod but the constant changing of CD's is annoying me.....
  25. campbell
    campbell Member
    726
    i was gonna go for the dension kit but now im going for the harman kardon drive and play 2, and im paying £190 for it. has anyone had this kit?
    you can hardwire it to the OEM headunit, or use the FM transmitter (sound will be poor) and the kit comes with a little lcd screen and mouse (all wireless) so you can scroll this your ipod etc. just a little extra money than the dension, and if anyone has had one of these units please tell us what the quality is like
    thanks
  26. 1animal1
    9,978
    i thought about this kit but dont want anything thats not OEM in the car, the denison is discrete..... cant even begin to think where you'd place the mouse or the screeen without it looking untidy
    Quality should be fine if its hard wired....
  27. Sanj
    Sanj Blue Beast
    175
    Does anyone know whats the difference between the Symphony 2 and the Symphony GEN II+ , I know i have a symphony 2 because its a front loading 6 cd changer built in.... I just had a look on the dension website and bit confused as to which one i have, any ideas????
  28. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    The GenII+ is the latest one I believe. It uses the different wiring/connectors from the 8P A3's. The only real difference is it'll play MP3 CD's and has a proper AUX IN for iPOD etc.
