Ipod Adapter for Symphony II Headunit
RobinA3 Dec 6, 2010
  1. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
    Chaps
    Does anyone know where i can get an Ipod adapter for my Symphony II (its the 6 disc changer one) headunit? There are loads on ebay but unsure which one will actually fit and work.
    A link would be great!
  2. RobinA3
    1,826
    46
  3. circleswim
    circleswim Lacks Car Funds...
    192
    I've got the dension gateway set me back about £100 but works well.
  4. roman3000
    roman3000 Member
    316
    I also have a dension gateway, its really good and displays song on the DIS.
  5. BlueSpark
    BlueSpark 6th Gear
    386
    I also got the Dension Gateway which displays track on the DIS. I would reccomend it as i've been using it for nearly a year now and works perfectly.
  6. Batt284
    Batt284 Member
    98
    Can you still play CD's if you instal the Dension or do you just lose the changer?
  7. circleswim
    192
    You can still use the cd changer. Mine doesn't show track names, just gives me iPod ui:iPod ui on the dis or aux gw when using aux in on it.
  8. Jonay
    Jonay Member
    274
  9. Wozski
    Wozski Member
    508
    cicrleswim there is a trick you can do to display track names etc on the display:-
    put the unit into iPod GW mode using CD 6 and track 3 and holding down FF for 3 seconds
  10. paul_r
    paul_r Member
    172
    Can you tell me how this works on a practical level.
    The ipod is in the glove box, for example, and its permanently connected to the 6 cd changer via the Denison Gateway.
    1. You turn on the ignition, does the music start straight away, or do you have to get the ipod out and turn it on, select album, etc.
    2. Can you control the volume using the standard volume knob on the symphony. Normally if you press the volume knob in, it turns the music off. Does this feature work with the ipod.
    3. When you turn the ignition off, does the ipod stop.
    I have just bought a 6th generation nano (yes the very small one) and am looking into getting it installed into my 2005 A3 sport. I have a feeling you might get different results with different installations.
  11. RobinA3
    1,826
    46
    So just to confirm the Dension works with the Sym II head unit (6 disc internal changer)?
  12. RobinA3
    1,826
    46
    How do i know if my headunit is a Symphony II or Symphony II+?
  13. circleswim
    192
    Woszki, just tried that "trick" but it didn't work for me. All I get is iPod ui as in pic of DIS below.
  14. paul_r
    paul_r Member
    172
    Circleswim, thanks for the reply. Specificaly, if you have the ipod playing, turn it off using the volume knob, then later turn it on, will it restart at the same place you stopped it at.
    You have the Denison, do other makes operate differently.
  15. RobinA3
    1,826
    46
  16. circleswim
    192
    paul_r
    yes, the volume button works exactly as it does when using the radio etc.
    Robin A3
    yes i do have the GW16AC2, i specifically requested it when i ordered as I wanted to have the track names shown as per this thread: http://www.audi-sport.net/vb/new-a3-s3-sportback-8p-chassis/67115-ipod-car-kit.html
    I have been using the kit for about 10 months now and love it apart from the fact it wont show my track names, ive come to the conclusion that as my car is one of the pre 2006 s-lines my DIS aint advanced enough to decipher the tracks names.... it may well be a load of rubbish but thats what it seems like to me!
  17. Wozski
    Wozski Member
    508
    i have the 32ac2 version i think - it works for me
    where abouts are living i could give you a hand if your local?
  18. circleswim
    192
    I'm about 20-30mins from Cardiff.
  19. Batt284
    Batt284 Member
    98
    I believe the II+ has a larger screen and no tape deck.
  20. RobinA3
    1,826
    46
    I have just ordered a Dension GW16AC2 kit for mine.
    I have read that the stereo removal keys from ebay are ****, anyone got any genuine ones which they wouldn't mind lending me?
  21. circleswim
    192
    The eBay keys may be cheap but shred your fingers to pieces because the edges are burred really bad and bend out of shape when trying to remove the headunit. I never actually managed to remove the headunit with the eBay keys. Order some of the genuine audi ones from your dealer, set me back £7 I think for the set of 4 keys. They did the job perfect first time! I have some you can borrow if your any where near south Wales...
  22. paul_r
    paul_r Member
    172
    1. Where did you order it from.
    2. Obviously, you are going to try to do it yourself. Let me know how it go's. (or even a photo diary, maybe thats pushing it a bit)
    Good luck anyway.
  23. circleswim
    192
    It's an easy job, plug n play.
  24. RobinA3
    1,826
    46
    I got mine from eBay for £130. Bloody expensive but cheapest place I could find it for. I will be fitting it myself. I'll do a guide for it when I come to do it.
  25. paul_r
    paul_r Member
    172
    Yes, they are blo0dy expensive.
    Looking on the Dension website there;s quite a few versions, text and non text, bluetooth, etc.
  26. paul_r
    paul_r Member
    172
    Have you fitted it yet?
  27. RobinA3
    1,826
    46
