iPhone to in arm rest phone prep
Boydie Apr 4, 2010
  1. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,410
    555
    Guys, quick question, is the iPhone compatable with the phone prep inside the arm rest?
    I have the the arm rest prep and just got an iphone and wondering if it will work and what do I need??
  2. webby1001
    webby1001 Member
    51
    im in the same postion as you atm lol. have you got the thing that you plug into the arm rest that you then plug your phone into. im not sure and dont hold me to this but i think you need a certain phone for it.
  3. JohnS3
    JohnS3 Active Member
    3,032
    You can get an iPhone adaptor. They cost around £100.
  4. Boydie
    3,410
    555
    Thanks mate - will have to look into it
    Do you have a part number at all or a link to it?
  5. bluenose
    bluenose Member
    You only need the cradle if you want to charge the phone tho. It will still work via bluetooth without the cradle.
    This is what i was told at dealership on friday? He said it was a waste of £100 quid.
    Can anyone confirm this is correct??
  6. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Yes that is correct.
    The other benefit of using the cradle will be that the phone uses the external antenna for signal, but I use mine via the bluetooth, and have no issues
    All other functions will be the same I believe
  7. jungleman
    jungleman Well-Known Member
    2,035
    42
    can i just check this then
    if u use the cradle, then it bypasses the bluetooth and is totally hardwired into the car, with in theory better signal and connection, as ive got a 3GS mine keeps randomly disconnecting and reconnection, tho not always :S
  8. CJ3BLUE
    CJ3BLUE Member
    96
    I believe it also activates the voice calling on the MFSW if you use the iphone with the cradle,but i also just use the bluetooth and works a treat !
  9. jungleman
    2,035
    42
    yea mine generally works fine, its just the random disconnecting that a bit of a pain lol
    but it hsnt cut a call off yet, so see how it goes, and to be fair cant see me moving away from an iphone for a very long time so if it does start to get on nerves then can always get a cradle lol :)
  10. JohnS3
    3,032
