Iphone and AUX-IN socket..
jacky Aug 14, 2009
  1. jacky
    jacky Audi newb!
    65
    Can you play music off your iphone by connecting it to the AUX-IN socket in the car??.. just like a normal ipod.
  2. royjk
    royjk Member
    167
    Why not try it
  3. pdv40
    pdv40 Member
    187
    Mine doesn't work with it. iPod Touch does but not iPhone.
  4. tdisportuk
    tdisportuk Member
    460
    thats strange..?
  5. kaz219
    kaz219 Active Member
    1,808
    I have a aux in on my other car and it works fine - finding a lead which fits the iphone is going to be a challenge though...
  6. Leenx
    Leenx Member
    145
    Mine does - I have the first gen. I bought this jobbie from Maplins for about £12 I think, although not great as the connection is not that secure, sounds fine though!
  7. martin 25th
    martin 25th New Member
    My 3g I phone works fine with mine
  8. andyb_88
    andyb_88 Member
    101
    should work fine, theres no difference between the two ipods
  9. NHN
    29,568
    1,779
    As long as the headphone outlet isnt setup in such a way it wont output sound unless an apple headset with proprietory wiring then should work just fine with normal jack socket on each end, note though the aux in socket is a very low level compared to radio/cd/mp3 so might require higher volume levels & remember when swapping back to radio etc to lower volume, gets me everytime, lol.
  10. borofoga
    borofoga New Member
    21
    Works with my iphone 3G.
    You just need to connect it with a 3.5mm audio lead (male to male).
    You have to play the music via the iphone and make sure the iphone volume and stereo volume is high enough to hear it.
  11. ragsterx
    ragsterx Rear Ender
    111
    Its an auxillary, very basic auxillary point to point, should work every time providing the cable is not f****d, or either auxillary port is not stuffed.
    Did you know you can use your iPhone as hands free when connected to the auxillary? The phone call is played out of your speakers and the mic on the iPhone is good enough to pick up your voice even when it is sat on the passenger seat.
    Cheaper option than Bluetooth and works at 70mph on the motorway too..
  12. NHN
    29,568
    1,779
    This is a true its a cheap mod if you know how to fit, but interms of usability, safe wise when driving, certainly not & its not auto switching for calls, requires switching inputs manually & the aux level is lower than the other sources so would have t raise volume to hear better, personally I wouldnt recommend but hey when its £20 or so for parts to fit against £3-400 then cant argue that one.
