internal diameter of DV hose?
russwuss May 10, 2013
  1. russwuss
    russwuss Active Member
    549
    106
    43
    Hi All,
    My DV hose had a leak when I first thought the car at the end (engine side) which I cut down and refitted - this worked fine with the standard TIP - however now I have the aftermarket TIP fitted it's not long enough and pulling the TIP up causing it to bend at the turbo side.
    Does anyone know the internal diameter of the hose so I can pick some up from a motor factors place, or is it a special reforced hose?
    Thanks in advance!
    Adam
  2. darren t
    darren t Member
    568
    same problem here 19mm won't be far off
  3. russwuss
    549
    106
    43
    thanks! you reckon this one will be ok then? just standard radiator hose
    Autobar Rubber Heater Hose 19mm
  4. StaceyS3
    StaceyS3 Well-Known Member
    2,487
    466
    Normal Dv size is 25mm id iirc, you may be thinking of the breather size which is 19mm id :)
  5. <tuffty/>
    20,847
    3,687
  6. darren t
    darren t Member
    568
    was indeed lol sorry!
  7. russwuss
    549
    106
    43
    Thanks for all the replies guys, ill order the forge kit.. Wouldn't hurt to change the N75 hose either! :)
  8. darren t
    darren t Member
    568
    the forge kit still dosent reach!!! You will have too extend the dv pipe still too stop from bending turbo tip !!
  9. darren t
    darren t Member
    568
    dv relocation kit might be best option atleast you get a new throttle body hose
  10. russwuss
    549
    106
    43
    Thanks Darren! Ill have to wait a bit for this.. Clutch is going :( so that takes priority!
