Intermittent Tail Light
themikeyboosh Jan 13, 2012
  1. themikeyboosh
    themikeyboosh Member
    68
    My tail light keeps going off, other bulbs ok. I can get the bulb back on if I take it out and put it back in but sometime by the time I've screwed the cluster back in it's off again when I test it! I've tried a new bulb but no luck.
    Any ideas? What's the part called which all the bulbs plug in to called? I've got a multimeter but obviously I can put one terminal on where the bulb touches, but where do I put the other one?
    Thanks for any help I appreciate it.
  2. The Engineer
    The Engineer Member
    355
    22
    Mine used to do this, i did a little investigation and found water to be getting in as my tail light was a little loose.
    once slotted in properly everything is fine.
  3. themikeyboosh
    68
    hmmm it has a little water inside I must admit. On the rubber rings around the 2 pegs has split, do you think that's how the water gets in? It's definitely seated correctly though.
  4. The Engineer
    The Engineer Member
    355
    22
    It may need drying out. Maybe worth removing it and put it in somewhere warm overnight.
  5. themikeyboosh
    68
    I'll give it a go, cheers
  6. themikeyboosh
    68
    If I wiggle the bulb it goes on and off, same with a new bulb.
    Would my best bet be replacing the whole bulb holder? I'v tried cleaning the contact with sand paper already.
  7. MarkTweedley
    MarkTweedley Member
    144
    I get this so often it's unreal. Normally drivers side break light bulb but occasionally the normal bulb. Annoying... Will check for moisture in the cluster etc.
