intermittent starting problem
samuelt Oct 5, 2007
  1. samuelt
    samuelt Member
    383
    hi all
    recently on the odd ocasion when i have got into my my car and turned the ignition it has struggled to turn over after about 3 attempts it starts! this does not happen every time. We thought it was my 5 year old key (used 7 days a week) as i drop it a lot and it's getting on in age, but it seems to also be happening with my wifes 15month old key we just use it less (one-twice weeks). The car has never not started and had a new battrey (bosch) 3 months ago.
    any advice welcome, tried to run search but for some reasson search only goes through the A3 section???
    thanks
  2. TINTMASTER
    TINTMASTER TORQUETRONIX-DONEGAL
    61
    could be the heater plugs m8!
    when you turn the ignition on to the 1st click (dash lights come on) wait til the heater light goes out and then wait a further 6 secs and then turn her over and see if that helps :icon_thumright:
  3. golf
    golf ***** rent boy VCDS Map User
    1,556
    Would help if you told us what engine it was.
  4. jase0851
    jase0851 Member
    789
    glow plugs wouldnt make the engine turn over slow, thats if it is a diesel sounds like a lazy starter to me how many miles ?
  5. marms
    marms Member
    833
    If you hadn't said you had recently change the battery I would have said it was simply due a change at 5 year old. I'd first of all get the battery tested just to make sure it's ok (if not get it changed under warranty). Otherwise it is almost certainly either a lazy starter motor or a bad earth to the starter motor.
    Good luck , hope you get it sorted without too much trouble (or cost).
  6. samuelt
    samuelt Member
    383
    sorry typed this in a rush yesterday! It's a 130 TDI 5 spped with 63k miles. It mainly does 8 miles a day (4x2) then the odd ocasion 25 to my parents and back.
    Glow plug light goes off in about 1-2 seconds, i dought i have ever wiated much longer , is the significance of wiating 6 seconds to see if they cool down to quickly???
    thanks
  7. jase0851
    jase0851 Member
    789
    no the glow plugs on audi tdi,s only work when they have to as much as they have to if you know what i mean. my old tdi used to do a quick flash in summer and on a cold winters day when you need glow plugs it used to stay on for about 4-5 seconds
  8. samuelt
    samuelt Member
    383
    This problem went away and is now back! The glow plug light goes out in about 2 seconds, then when i try to start it i have to hold the key fully round for about 3 seconds to start the car. it is currently very cold in perth could this be affecting it? any other ideas?
  9. jase0851
    jase0851 Member
    789
    did you change the glow plugs then ? like i said the glowplug light shouls stay on for longer on colder days
  10. samuelt
    samuelt Member
    383
    no i have not changed them is this easy DIY?
  11. arthurfuxake
    1,308
    I'd get the battery checked first. Sounds like it's not providing enough power to turn the starter motor fast enough, and it's compounded by the cold temperature.
  12. jase0851
    jase0851 Member
    789
    he has changed his battery read the first post
  13. arthurfuxake
    1,308
    Just because he changed the battery doesn't mean it's not a faulty battery! It's a 2 minute job to check the current of the battery, and diesel engines need a more powerful battery than the equivalent petrol engine, so he might have the wrong battery! So, before you start ripping out glow plugs and starter motors, just make sure that the battery is ok, and that the charging voltage from the alternator is good. A knackered battery after just 3 months could be a symptom of a knackered alternator.
  14. arthurfuxake
    1,308
    As highlighted in this post: http://www.audi-sport.net/vb/showthread.php?t=47617
    So, at the risk of repeating myself, get the battery checked and make sure you've got the right size battery for your car before you start ripping out bits of the engine.
