Intermittent Lack of Boost
mastas3 Nov 22, 2009
  1. mastas3
    mastas3 New Member
    12
    Hello,
    I am having a strange problem with the S3 lately. After starting up, and warming to ~90 degrees - the car is not boosting right. It's like no boost from turbo at all. If I stop down and restart - nothing - the same as before. If I leave the car a few minutes and then try again - It's back to boost. But then again some times after a bit of going strong it's back to square one - no boost again. It's driving me crazy.
    What is your opinions on this?
    Regards
    Gabi
    PS: no codes on Vag Com
  2. wagon
    wagon cock locked and ready to rock
    130
    hi gabi,
    i had this same thing,
    ended up changeing quite alot to find out that the problem was a faulty n75 valve. i had maf, boost pipes etc all changed.
    still get it sometimes but i think i need to change the maf again as i had a used one put in and havnt swapped them back.
  3. mastas3
    mastas3 New Member
    12
    I am also suspecting N75 after reading alot. But, wouldn't it throw some code in Vag Com? Is there a way to test it?
    Thanks again
    Gabi
  4. wagon
    130
    not sure really, i just stood there and smoked while the guys at storm developments had there head's in the engine bay. test run after test run after test run.... fixed. but they said they changed the n75 and it was fixed. mine would boost only at 4k and i would get the whole lot at 4.5k. then it would go into limp mode (maximum boost presure exceded) was the vagcom error. strange how yours doesnt log a fault....!
