Intermittent knocking from front suspension
skinnyman9000 Mar 1, 2011
  1. skinnyman9000
    skinnyman9000 New Member
    22
    There is a knocking sound coming from the front right of the car, it doesn't always happen and when it does it's only at low speeds. Driving normally the car feels fine, but when it knocks you can feel it.
    Any ideas what this is likely to be? it sounds like it should be fairly straight forward tbh
  2. a4 cabrio
    a4 cabrio Member
    135
    cv joint maybe, mine knocked a bit when it went
  3. aragorn
    18,579
    868
    You really have to jack it up and have a look. There are a million balljoints that could be worn!
  4. skinnyman9000
    22
    Well this is purely a workhorse, so my idea was to ignore it until it breaks. Sound like a fair plan? Or will this end in tears?
  5. aragorn
    18,579
    868
    If its a balljoint, and it breaks, your wheel will be nicely flapping around in the arch, not really what you want happening at 80mph...
    Get it jacked up and see whats worn.
  6. skinnyman9000
    22
    Suppose I'll have to take a look at the weekend. From past experience tho knocking noises at low speeds/full lock haven't caused major issues. Just trying to out the work off I guess
  7. nwmlarge
    nwmlarge flat out
    219
    get a pry bar to lever the joints about to find which joint is the loose one.
    it's prob the track rod end or the cv joint
  8. Tuffty
    Tuffty Member
    127
    Anti roll bar bushes or links are likely suspects
