Intermittent door electrics problem?
welshwoody Feb 27, 2012
  1. welshwoody
    welshwoody Member VCDS Map User
    438
    10
    A close friend of mine also has an Audi A3 Sportback and has recently been having intermittent doorelectrics problems. Basically the door electrics work off and on like the windows not working and the illumination also not working. I thought maybe it was a loose connection on the door but after running the scan through VCDS im not sure as its flagging all 4 doors? Surely it wouldnt be that all 4 doors suddenly have loose connections?
    What would you think the problem is from this report? Convienience module?
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-B.lbl
    Part No SW: 8P0 907 279 J HW: 8P0 907 279 J
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007305431
    Coding: 00880F01B0141000471600001600000000085A175C010000000000000000
    Shop #: WSC 06314 000 08192
    VCID: 448C3B360780FE3
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    3 Faults Found:
    00988 - Lamp for Brake Light; Right (M10)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 110937 km
    Time Indication: 0
    Date: 2012.02.03
    Time: 19:56:00
    Freeze Frame:
    ON
    Voltage: 11.95 V
    ON
    ON
    OFF
    OFF
    OFF
    01334 - Door Control Module; Rear Right (J389)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 200
    Reset counter: 217
    Mileage: 109475 km
    Time Indication: 0
    Date: 2011.12.31
    Time: 15:03:00
    Freeze Frame:
    OFF
    Voltage: 12.50 V
    OFF
    ON
    OFF
    OFF
    OFF
    01331 - Door Control Module; Driver Side (J386)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 188
    Reset counter: 217
    Mileage: 109629 km
    Time Indication: 0
    Date: 2012.01.08
    Time: 22:06:00
    Freeze Frame:
    OFF
    Voltage: 12.20 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K07705828B
    Coding: E9807F060002022103
    Shop #: WSC 06314 000 00000
    VCID: 306467E6A338723
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 208
    Reset counter: 217
    Mileage: 109475 km
    Time Indication: 0
    Date: 2011.12.31
    Time: 15:03:22
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 207
    Reset counter: 217
    Mileage: 109481 km
    Time Indication: 0
    Date: 2012.01.02
    Time: 16:47:46
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H10 0080
    Coding: 1980202002186D0985054C9FC637
    VCID: 438E382A028EF9B
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    2 Faults Found:
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Component: Tuer-SG H03 0040
    Coding: 0000688
    2 Faults Found:
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 152 C HW: 8P0 035 152 C
    Component: R Chorus2+ H16 0240
    Revision: 00H16000 Serial number: AUZ1Z2G9188556
    Coding: 0000221
    VCID: 2B5E708A8A1E11B
    No fault code found.
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    VCID: 418232221892EBB
    1 Fault Found:
    00934 - Electric Window Motor; Rear Left (V26)
    005 - No or Incorrect Basic Setting / Adaptation
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000144
    VCID: 42803D2E1D94F03
    1 Fault Found:
    02071 - Local Databus
    End ---------------------------------------------------------------------
    Thank you
  2. NHN
    29,300
    1,702
    1st check the wiring in those 2 right front/rear doors between pillar & door grommet?
    Seems the right side at fault, not left, left is just window 1 touch needs resetting.
  3. welshwoody
    438
    10
    Ok Thank youIll see ifshes free to let me check it later.
