Intermittent brake warning light on DIS when firing up my 2005 A4- B7
psychopomp1 Dec 13, 2012
  1. psychopomp1
    psychopomp1 Member
    164
    14
    Hi
    Every now and again (say 2-3 times a month) immediately after switching on the engine, i get the red brake warning light on the DIS but it always goes away after a second or two. Reading the manual this should happen if you attempt to drive the vehicle with the handbrake still on but obviously in my case the car is stationary. Any idea why this happens? The car is going to the Audi garage tomorrow for something else so i'll ask them to take a look at this as well.
  2. Gazthesparky
    Gazthesparky Member VCDS Map User
    217
    I had a similar problem with my passenger side rear light.
    The indercator bulb went so took the light out to change the bulb. I wasn't sure which holder it was and disturbed the red rear bulb instead. I changed the indercator all was ok but every so often I would get a dis warning me the passenger rear light not working.
    I would get out and tap the light and it would work. This went on a few weeks and then I got fed up of it so changed the bulb and since then no problems
    I suggest you change the bulb and check its seated correctly and succurly into the holder and light assembly
  3. psychopomp1
    psychopomp1 Member
    164
    14
    Thanks mate but which bulb(s) should be changed? Rear light bulbs have never been touched, i got oem bi-xenons fitted 6 months ago but this problem was happening before then.
  4. alpesh26
    alpesh26 Active Member TeamMisano
    414
    42
    Might be worth getting your battery tested. Mine used to do this and since I changed the battery the problem went away.
  5. hades-
    9,481
    646
    as above check batt
  6. psychopomp1
    psychopomp1 Member
    164
    14
    thanks chaps, will ask my audi dealer to check the battery
  7. Craig Cull
    Craig Cull Well-Known Member
    2,348
    1,231
    mine does this everything I start the car. Mines had a new battery and hasn't made a blind bit of difference. It also did it as I came off a roundabout this morning. Apparently it's something to do with the brake fluid reservoir. It needs changing. This is according to a couple of people on here. But... I've also been told its to do with the fact that there is no cover on the battery compartment. With the main wiring harness running all the way through the battery tray, apparently it can cause a short to the brake sensor when cranking over. I haven't managed to solve the problem yet as its too close to Christmas. Hope this helps :) would love to know audi's conclusion
  8. Gazthesparky
    217
    Hi I've just re read the original post. I obvuisily didn't read it correctly the first time lol I thought that it was refuring to the bulb out warning on the DIS. In actual fact I see that it's refuring to the red warning on the dis.
    My previous post was refuring to the bulb out warning in the dis. Sorry to cause any confusion
  9. ctd
    ctd Member
    106
    mine does it now and again, checked everything and can't find a problem, sounds like a common problem so not that bothered about it now, just check fluid levels every couple of weeks just in case
  10. d4dubs
    d4dubs New Member
    27
    I get this also on my avant.. Had pads checked as thought it may be warning on them getting low... They had at least 50% of meat left. I also don't have a cover over the battery and notice this happening in the mornings mostly.
  11. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    439
    Check fluid levels
  12. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro s tronic saloon
    1,511
    386
    Mine does this sometimes too. I dont have a battery cover and ive had both rear and front discs/pads changed very recently so battery cover or brake fluid level maybe the answer i guess
  13. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    I get the yellow '(O)' brake pad warning symbol come up sometimes (probably once a month) even though my brake pads aren't low. I have the battery cover fitted and my brake fluid level is fine.
  14. hades-
    9,481
    646
    whats with the battery cover ?
    the beeps can be from a weak battery nothing to do with not haveing a cover
