Intermittent Boost / Overboost
TanyaS3 Jun 3, 2009
  1. TanyaS3
    TanyaS3 Member
    204
    Hello!
    Its been a while...... but I need some help please.............
    My S3 has a problem with intermittent boost. It will either not boost at all or massivley overboost to 25lb !!!!. Ocasionally it will boost normally. I also notice that the wastegate seems to chatter different amounts randomly (either a very small amount or fairly audible). The ambient temprature seems to make no difference. Has anyone else had this problem? Any help would be appreciated.
    Tanya
  2. Sandip
    2,440
    91
    Could be the N75 valve, dumpvalve or N249
  3. TanyaS3
    TanyaS3 Member
    204
    Thanks.
    I have spoken with Audi parts regarding the two valves. N75 and N249 seem to denote a number of different solenoid valves in the system. Is there anyway to figure out which valves I would need to replace ?. The car has been checked on with a diagnostic tool. The system displays : -
    01 - Engine electronics
    8N0 906 018
    1.8L R4 5VT
    Coding 5610
    value above maximum charge pressure
    Any info much appreciated
  4. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    Idealy you need to use vag com to check/ log the figures,
    Where abouts are you??
    I changed most of the control solanoids on my car ( it isnt cheap to just start changing things in hope )
  5. TanyaS3
    TanyaS3 Member
    204
    Hello, changed a part, I think N75 located at top of engine under cover and it all works fine and is holding boost nicely :)
    thanks for your help and advice
    Tanya
  6. ianysm
    ianysm Active Member
    1,002
    sounded like dv problem. This is at top of engine.
  7. S3Steve
    S3Steve Active Member
    1,609
    17
    The N249 valve is the one ontop of the engine under the cover, the dv and N75 are both located on the tip.
