Hi,
Had this problem for some time but only getting round to sorting it now (along with all the other issues) as my mot is due.
The abs light first started to appear after I changed the starter motor. I only usually do basic servicing with the car but felt a bit adventurous when the starter motor failed so I did this myself and all went well. As soon as the started motor was changed however the light appeared and has been on ever since - usually after i've been driving for a minute or so.
I bought a cheap cable to use with VCDS-Lite which gives the following codes:
Address 01 Engine
16955 - Brake Switch (F) Implausible signal - Intermittent
16795 -Secondary Air Injection System: Incorrect Flow Detected- Intermittent
16500 - Engine coolant temperature sensor (G62) - Intermittent
Address 03 ABS Brakes
00778- Steering Angle Sensor (G85)
27 - 10 Implausible signal - intermittent
Some of these are likely related to the esp light which again has been on for some time after a trip to the garage - I was under the impression it was something to do with the tracking as it's something I haven't got round to fixing yet. Also, my temp gauge never sits at 90 so I'm guessing the engine coolant temp sensor is the cause of this??
I've read through lots of posts already but just thought I'd ask for some advice - one thing I read was how things can be reset after removing the battery?? so something like this would be the easiest fix.
Also - I only have the vids lite so can't clear codes or adjust settings (i'd probably take to the garage for this)
Any help and advice would be very much appreciated!
Thanks!
Address 01 Engine
Thanks!
