Interior ultrasonics button not working?
reggieroo May 26, 2011
  1. reggieroo
    reggieroo Member
    259
    I seem to having trouble with disabling the ultrasonics in the S6 when I leave my GSD in the car, well the trouble is the button isn't disabling the interior ultrasonic sensors so Zeus sets of the alarm when he moves. When I push the button, the red light doesn't come on anymore indicating they have been disabled, faulty button?
  2. Mudplugger
    Mudplugger Member
    98
    My button was broken when I bought the car. The replacement from the Audi main dealer was about £15 IIRC, so you could do worse than buy one and try?
  3. reggieroo
    reggieroo Member
    259
    I may just pop to the Audi garage then & buy a button, as poor Zeus hasn't been able to come out with us due to not being able to turn off the interior sensors.
  4. ms1083
    ms1083 Member
    148
    When my alarm goes off I can see which sensor has set it off using my fault code reader, think its under central locking section. May be worth checking what has activated alarm.
  5. reggieroo
    reggieroo Member
    259
    I've actually tested it with Kate in the car, pushed the button & Kate waves her arms & off it goes. I first noticed it not working when we left Zeus in the car one day, came back & the alarm was going off. It doesn't go off any other time, so guessing it the ultrasonic sensors.
  6. reggieroo
    reggieroo Member
    259
    Right I got a new button but it still doesn't work? Even the new button the red light doesn't come on when you press it.
  7. wilkoa6
    wilkoa6 New Member
    14
    I had a similar problem. The microswitch in the drivers door lock was not working so the car did not know if the door was open or shut. Does the door open indicator work on the screen by the speedo? Replacing the door lock sorted the problem and I could then de-activate the alarm for the dog. Let me know if this helps.
  8. reggieroo
    reggieroo Member
    259
    Did your dooor still lock though, as mine does?
  9. wilkoa6
    wilkoa6 New Member
    14
    Yes...the door lock was still working it was just the microswitch that was broken. You could not disable the alarm with the switch in the door until this was working.
  10. reggieroo
    reggieroo Member
    259
    How did you know the microswitch wasn't working, is there a way to test it before shelling out for a new lock etc? My LCD display is on the way out but haven't noticed it showing the door open.
  11. reggieroo
    reggieroo Member
    259
    Have now checked to see if the drivers door shows as open on the LCD display & it does not. All other doors show as open except the drivers door. Where is this micro switch located & how much was it?
