Interior Rattle
Chrismawa Feb 21, 2014
  1. Chrismawa
    Chrismawa Active Member
    457
    46
    My cars just developed an annoying rattle when driving along. Its rattling even when not going over harsh bits in the road. It sounds like its right next to me on the drivers side, so was thinking maybe drivers or rear door?
    Are there any common rattles it could be? Its driving me nuts!
  2. BakPak
    BakPak No Gear
    957
    137
    43
    An old car I had did my head in for a couple of weeks with a constant rattle, turned out to be a small bit of suspension spring rattling around in the mounting cup.
  3. Wahlstrom
    Wahlstrom Active Member
    412
    147
    43
    Just did my headrest.. It could move sideways and made noise when doing so.. Slammed it to the seat.. No noise now..
  4. BakPak
    BakPak No Gear
    957
    137
    43
    Whiplash
  5. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
  6. Mike_B
    Mike_B Active Member
    533
    47
    Drive around with someone else in the car, perhaps in the back seat. If you know any medical type people with a stethoscope, that's a really good way to track things down. Also check the various heat shields under the car, they are known to come loose as the fasteners corrode.
  7. deano1978
    deano1978 different gear
    713
    81
    I have this too,got a pal to drive as its doing my nut in!
    Well traced it to rear passenger side. Seems to rattle behind seats nxt to wheel. Cant get behind the tupper ware.
    Very frustrating
  8. BakPak
    BakPak No Gear
    957
    137
    43
    Check the rear spring for a piece broken off and rattling around.
  9. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,716
    162
    My avant does this too. To fix it it took all of 5 seconds. I just removed both of my hearing aids and the noise has gone! It's amazing. The wife argues that I haven't fixed. But I have, because I can't hear it anymore! Job done.
    But seriously it's trim in the boot I think that rattles on mine....
    Christine is a different kettle of fish! Hearing aids or not I can ruddy here the thing rattling away!
  10. deano1978
    713
    81
    Ha,mines more directly behind the rear seat. Not really coming from the wheel lining as such.
    Near the top of seat belt but sort of behind it
  11. Wahlstrom
    412
    147
    43
    I thought that too, even had the rear door card off to find it.. Until I gave my headrest a shake.. Then I found the problem... Sounded like seatbelt/ rear door
  12. Chrismawa
    457
    46
    Found it! I think it was the load cover. Annoying as hell but stopped now :)
  13. S4_dan
    2,716
    162
    Can you explain a little more please? My rattle could be coming from there too! :)
    Dan
  14. deano1978
    713
    81
    I thought that too,too.
    So removed mine,still there :-(
  15. krisavant
    krisavant Active Member
    449
    61
    Load cover are known for this and the headrest rattle.
    As WAHLSTROM said, slam the headrest down to get rid of that rattle.
    Load covers (on Avants) need to be slid onto the seats all the way down and the hook things tend to rattle.
  16. marco-polo
    marco-polo New Member
    Mine rattles on the fuse box cover to the side of the dash, It never did until I disturbed it when having to replace a fuse.
    Can't get rid of it now, its here to stay......
  17. Chrismawa
    457
    46
    The end flap of the cover (where the handle is to pull it) was caught and was stuck pointing down into the boot. Once I moved it to its correct place, no noise :)
  18. Wahlstrom
    412
    147
    43
    Or swap them..
  19. deano1978
    713
    81
    Really. I actually sat in the back and cld nesr enough pinpoint it towards the top end of seat belt. Wish is was head rest!
    Some how got to get behind the tupaware (behind rear seat) :-(
  20. MooLard
    MooLard Member
    229
    Any joy in sorting this? My rear load cover was giving me grief and kept coming off of the hooks too, but I made some wooden lugs and glued them in place, made them about the same shape as the Audi fix for them, and it's worked.
    The remaining rattles now appear to be the windows, they are electric front and rear and potentially the cables in some of the windows are a little slack, or a plastic holder / retainer has cracked in the door.
  21. Wahlstrom
    412
    147
    43
    Anyone with rattle where the bass sits.. When music is playing and I'm outside the car I can hear this bass-rattle.. Checked where it sits and everything seems tight...
  22. deano1978
    713
    81
    Found my f,in rattle noise!!!!!!!!!!!!!!
    Gave up looking from the top area.
    Removed wheel (rear p/s) wheel and arch lining,bang! There it is...
    Missing bolt from the top strut of the damper.
    Make things worse the nut was still in there,no head!
    Drilled it out,new bolt in.
    Oh im so happy now no rattling :yes:
    Mike_B and DieselJake like this.
