Interior light wont go off whilst driving! Says doors still open! ITS NOT!!!
hillg81 Jul 19, 2010
  1. hillg81
    hillg81 Member
    94
    Right!
    Ive noticed recently that sometimes the interior light doesnt go off when you drive!
    But then it does a few hours later if you try it!
    Today and tonight its not gone off once, it shows up on the dash that the drivers door is still open
    Its not open its closed!
    Also if you in the car and try and lock the car using the button on drivers door it wont lock!
    When you get out and use the central locking it works fine but once again light stays on inside!
    Common fault??
  2. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Get contact cleaner from Maplins and spray a bit inside the door catch mechanism on the door. Shut the door and it should be fine. Mine used to do this all the time but now i've been sorted with contact cleaner. I had to spray it every few days but it looks like it's sorted itself out completely as i haven't had to do anything for a few months now!
  3. s4mark
    s4mark Member
    297
    10
    mine is also suffering from this issue, have been spraying cleaner into and it seems to solve it for a week or so. Strangley seems to be fine in the morning or if the weather is cool but if it sits in the sun and gets hot then it almost always plays up. Have read somewhere on web that it may be the solders on the microswitch itself that have broken (aparently this is a common problem) and there was a guide on how to fix it but in my opinion seemed like a load of hassle. Gonna get a new door catch for around £50 from Audi i think.
  4. 1.8tplym
    1.8tplym Member
    49
  5. drfeelgood
    drfeelgood Member
    225
    I had the same fault when i first bought the car, had the drivers side door look replaced and it fixed the issue
