Interior light package
vanaaken May 21, 2008
  1. vanaaken
    vanaaken Member
    121
  2. JohnS3
    JohnS3 Active Member
    3,032
    Straight swop, if you get the top item you don't need the lower one as it's built in!
  3. ianspibs
    ianspibs Member
    119
    You don't need to buy both items, just choose one of them depending whether you want map reading lights as well as the LEDs.
    .....and yes it is a simple swap for the ambient light pack.
    If you just go for just the LEDs you need to remove your existing unit and drill two holes.
  4. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    as above really.
    I opted to buy the whole unit rather than just the LEDs.
  5. JohnS3
    3,032
    I fitted the LED unit to my rear cabin lights. A bit like this....
    Be careful if you're going to drill holes in your existing unit as it's moulded from a light grey plastic which is sprayed black. I used a CD marker pen to cover the visible grey bits.
  6. MarcQuinlivan
    2,539
    how much did that set you back?
  7. JohnS3
    3,032
    Just a tenner for the parts from vagparts, a bit of carful measuring and a few runs through with the drill.
  8. MarcQuinlivan
    2,539
    ah, you just bought the LEDs. Thought you bought the whole trim. Are the holes pre-marked on the back of it, or did you have to do a DIY on it?
  9. JohnS3
    3,032
    No holes marked so it's all DIY. You can use the front one as a guide though.
  10. MarcQuinlivan
    2,539
    mights add that to my list of mods. a nice red glow in the rear might be nice!
  11. Astakos
    Astakos Member
    30
    Can this one be fitted to a new S3 8P? I didn't order mine with the light pack as well...
    Will it be a straight swoop or any other mods are needed?
    Thanx in advance!!
  12. MarcQuinlivan
    2,539
    Yeah, direct swap. you'll just need to make sure you order the right one - if you are unsure, just give VAGParts a call with your chassis number and they'll tell you which one you need.
    The S3 has black roof lining doesn't it? If so, then it is the Soul Black one you want. You'll know if you have a sunroof or not, and then it is just a case of checking if you have the airbag deactivation light on your existing cluster.
  13. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    Ooh Err!
    I know but it had to be done...
  14. MarcQuinlivan
    2,539
    I was waiting for that response!
  15. Astakos
    Astakos Member
    30
    Thanx a lot for your info mate!
    Will surely give them a call...I really want this upgrade!! (map lights and ambient led). :yes:
