Just to update this thread, I've found solutions as below courtesy of the Audizine forum and members DavidB8 and Rlarsen:-
Footwell lighting:-
MMI high (2G):
Code:
Enable the Interior lighting (extended) MMI item:[07 - Control Head][Adaptation - 10] -> Channel 1add 2 to the existing value
MMI Plus (3G):
Code:
[5F - Information Electr.]Not know yet how to enable the Interior lighting menu item with VCDS....BUT can be enabled through the "hidden menu":- select 'Interior Light' in 'car/cardevicelist'- put 'Interior light' on 1 in 'car/carmenuoperations'
MMI basic (non-MMI - 2G) (symphony/concert radio):
Code:
[56 - Radio][Coding - 07] -> Long Coding Helper -> Byte 8Bit 7 - Interior Light Settings active - (1 = active)
Then enable the 'connection' between Cent. Elect and the Interior light MMI menu item (the same on all systems):
Code:
[09 Cent. Elect.][Coding - 07] -> Long Coding Helper -> Byte 16Bit 6 - Set this bit manually to 1 - (1 = active)
If the menu item is still grayed out - then a restart of MMI is required now...
More info see:-
http://www.audizine.com/forum/showt...ng-(Full-time-adjustable-foot-lighting)/page3
Instrument Backlights always on:-
Haven't really found a solution to this more a work around. Use the following coding
Always on 100% LED lighting
- SELECT [Module 09]
- Go to "Secure access" [Enter code: "20113", accept]
- Go to "Adaptation" [Select "Channel" 3 ", inserting the No. or by pressing" Up "]
- Choose the percentage of light that we want minimum 5 and maximum 100.
- Click "Test"
- After clicking Test confirm with "Save"
This setting will turn up the brightness of the LED's to full power when used as sidelights so you can swith DRL to side lights and have front and rear LED's and instrument lighting. (The DRL setting alone will not always light the instrument cluster). The LED's are also on full power when headlights are on which looks quite good. Only drawback is that the LED's do not dim when indicating.
(see :-
http://www.audizine.com/forum/showthread.php?278256-Cool-VAG-COM-codes/page14 post 553)
(All credits go to those concerned and shown within links above)
