I got a couple of LED map light bulbs off a mate who had a couple spare n they don't work. They do work when you put them on a battery though. Wondered if anyone had any insight to this problem?
Pretty sure they are polarised so try them the other way around... had this with the glove box LED on mine when I recently swapped all my interior bulbs for LEDs... glove box didn't work, turned the bulb around and bingo...
Yeh that's the case for the dome type bulbs as had that issue with my number plate lights but I'm having trouble with the map lights which look like sidelight bulbs. They have 5 LEDs on them, 1 on the end and 4 round the edge.
Done all my interior leds.as mentioned just turning them around should solve the problem.think with my map lights i had to bend the contacts slightly as they werent making a good connection
