Interesting discovery
matt116 May 19, 2006
  1. matt116
    matt116 Member
    41
    Checked my S3 on VAG COM and it reported a problem with the N249 valve - open circuit. I purchased the valve without checking the original one (couldn't find the time) so when I came to fit the new to my surprise discovered the electrical connection hidden behind a metal plate - not connected to anything.
    I have now plugged it in withour fitting the new valve as it was raining and it doesn't seem to run any different. Could anyone tell me what the valve does and what the electrical connector does.
    Matt
  2. s3bow
    s3bow Member
    379
    I had a fault code with the 249 too. Mine was "mechanical malfunction".
    PaulS3 said something about making sure the electrical connection was connected.
    It's the vacuum solenoid that controls the recirc valve.
    Chris.
  3. PaulRS3
    PaulRS3 Well-Known Member
    1,215
    149
    yep n249 controls the diverter valve.
    the valve is told by the ecu, via the plug, when to send vacuum or boost to the diverter valve to open or close it.
