Intereior lights not going out!
AudiiduA May 30, 2010
  1. AudiiduA
    AudiiduA Member
    359
    Hi all. i noticed the interior lights arnt going out and the info panel says drivers door still open! seems to be much worse the hotter the weather! anyone had a similar prob?
    Cheers fellas:)
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    microswitch on the door....I had it and you might also experiance the three beeps from your alarm in the morning because its doing overtime
  3. AudiiduA
    AudiiduA Member
    359
    Cheers for that! but where is it located as i have looked and cant find anything????? usually a button or summat!!!
  4. Nilz
    11,356
    894
    Do a search mate, there is a full write up on here somewhere, I used it and so have a few others and it works a treat, basically, you need a wire hanger and need to have a feel around in the locking mechanism on the side of the door, you can tell you are touching it as the light on the inside of the door will go on and off when you make contact, it just needs a tug to sort it.
  5. Prawn
    11,540
    3,494
    Mine old one does this too, in Really hot weather it wouldn't recognise the drivers door being shut.
    As a result, your alarm also won't arm when you lock the car....
    Most annoying
  6. Perplexer
    Perplexer Member
    239
    My S3 used to do this all the time and very rarely now since I poked the microswitch with a coat hanger wire and lagged the switch in Molyslip spray. If it does 'stick', a normal (none forceful) door open-shut usually cures it.
  7. AudiiduA
    AudiiduA Member
    359
    Cheers all! off to find a coat hanger lol:laugh:
