Interchangeable centre caps
munchkincoupe Jul 9, 2012
  1. munchkincoupe
    munchkincoupe Member
    948
    19
    How interchangeable are Audi wheel centre caps - I'm after a set of 8T0 601 170 for my new wheels as the current ones have seen better days
    All of the sets on ebay are different codes or cheap replicas - would 8D0 or 4D0 code centre caps fit too?
  2. boomtown
    boomtown Member
    130
    60mm are what you need i believe, i got mine from ebay standard audi 4 ringed ones, genuine parts
    £10 delivered made a big difference aswell !
  3. munchkincoupe
    948
    19
    The ones I need to replace are 63-64mm across the face or 53-54mm across the compression ring!
  4. boomtown
    boomtown Member
    130
    60mm will fit perfectly
  5. munchkincoupe
    948
    19
    Thanks will order some then - fingers crossed
  6. munchkincoupe
    948
    19
    Thanks for that . . . . . . . . if by fit perfectly you mean they wobble about and then fall out
    60mm don't fit
    Anyone need 4 new centre caps - 4B0 601 170 ?
  7. lmuckenbach
    lmuckenbach New Member
    Hi. I know it's been a while, but what did you wind up doing for center caps? I'm in the same boat you were. The 8T0 601 170 is hard to find unless you want to pay $50 each from the dealer or order from some sketchy site online.
  8. munchkincoupe
    948
    19
    Got 2 from the dealers in the end
  9. jonboy029
    jonboy029 New Member
    Ok, so I'm searching for a set of the same 8TO 607 170 centre caps for my 61 plate a4 s line. Any ideas in the UK?
