Integrated Engineering Forged Connecting Rods for 1.8T
davkav Mar 18, 2014
  1. davkav
    davkav Member
    164
    Selling my Integrated Engineering rods for 1.8T applications.
    I am using my Pauter rods for my build so these are no use to me.
    They are for pistons with 19mm wrist pins so suit most 1.8T's post year 2000. Suit engine codes AMB, ARX, ARY, ATW, AUM, AWM, AWP, AWW, BJX to name a few.
    If you have an engine code for me I can check if they suit.
    These will suit up to 700bhp (from IE's website).
    Rods have new bushings on the small ends as they where used but only for 1,000 miles.
    I have 1.8T pistons (9.5:1 compression ratio) spare if the buyer wants to take them too (for a price) and I can get the rod bushings honed to suit the pistons.
    New rods bearings would be required also.
    Spiel from the IE website:
    2 Piece Forgings from Vacuum Drawn 4340 Chrome Moly Steel
    Multi Stage Heat Treat for maximum strength, dimensional stability, and fatigue life.
    Fully Machined and Shot Peened
    Optimized H beam Design
    Tolerances as tight as .0003 ground on Sunnen brand equipment
    Standard ARP2000 Rod Bolts
    Computer Optimized Design
    Magnaflux Inspected
    Dimensionally Inspected
    Packed in balanced sets +/- 1 gram.
    VW/Audi 1.8T engines with 19mm wrist pins
    Combination tested to over 700HP+
    Possible to install without removal of engine
    I am after €200 for them but obviously open to offers. Ill include the pistons for an extra €60. Honing the rods to the pistons is roughly €80 and I can get this done if required using Westward Engineering.
    Cheers,
    Dave
  2. daneastwood
    daneastwood daneastwood
    23
    do you still have these rods for sale mate
  3. davkav
    davkav Member
    164
    Still here man
  4. daneastwood
    23
  5. davkav
    davkav Member
    164
    I can send photos this evening when I get home.
    As per the first post though, they are not brand new unused.
    They have less than 1000 miles on them as they were fitted incorrectly by a mechanic.
    They were removed and I went a different direction with my build.
    They have since had new bushings fitted to the small end so they are more or less brand new, you would just need new big end bearings for them which are roughly €60 for the set.
  6. daneastwood
    23
    What about the pistons ?? are they standard pistons or aftermarket
  7. davkav
    davkav Member
    164
    Standard 1.8T pistons with 9.5:1 compression
  8. Craig Cull
    Craig Cull Well-Known Member
    2,451
    1,409
    Might be a long shot but are the rods any good for a 2.0t fsi BUL?
  9. davkav
    davkav Member
    164
    Not too sure but I will find out.
  10. davkav
    davkav Member
    164
    Pictures:
  11. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Just to jump on ninja style (sorry davkav) I'm selling some brand new rod bearings that will work perfectly with these Rods 😉
  12. davkav
    davkav Member
    164
    Sold
  13. adam-
    adam- New Member
    Yaaaaaaaaaaaaayyyyyyyy! :)
