Intake manifolds.
Dani_B19 May 11, 2009
  1. Dani_B19
    9,365
    400
    Browsing through ebay early and came across this:
    http://cgi.ebay.co.uk/AUDI-1-8-20v-...9|66:2|65:12|39:1|240:1318|301:0|293:2|294:50
    I know the colours awful but im sure i once read somewhere on here that the inlet manifold is restrictive (can someone confirm), but would that be anygood?
    Also did a bit of back reading through past post and something came up regarding dahlback, had alook on the web and found this also, half way down:
    http://www.dahlbackracing.se/english/main.asp
    Seems agood price too.
  2. I'm not sure that'll fit your S3, the entrance to the intake manifold is on the left which is for 1.8Ts with only one SMIC, the S3 has two SMICs so the entrance to the intake manifold is on the otherside....
    S3
    Golf (with one SMIC)
  3. h100vw
    h100vw Member
    218
    That's off a Passat or A4.
    Gavin
  4. Broken Byzan
    13,237
    465
    Deffo A4/Passat Unit. its a lot of money for some paintwork and a bit of dremeling too
  5. Dani_B19
    9,365
    400
    Im guessing you guys are talking about the ebay item, what do you think to the dahlback?
  6. h100vw
    h100vw Member
    218
    Are you making 300 hp already???
    Gavin
  7. Dani_B19
    9,365
    400
    No cheif. But i am keeping the s3 for some time so eventualy i aim tobe. Im guessing your asking due to the description of the dahlback manifold.
  8. Shy19s
    Shy19s Oil running through my veins.
    886
    APR do an aftermarket inlet i think.. but you need uprated conrods to run it, apperently makes a hell of a difference.. awesomegti.co.uk supply them but im sure you can look around for different prices and alternatives..
  9. Dani_B19
    9,365
    400
    How much would the conrods set me back? Think ive seen the apr kit but was quite dear if i remember.
  10. Dennis Moeller
    Dennis Moeller Member
    444
    I have the Dahlbäck intake. No gains except (theoretically) better airflow. I haven't measured intake temp but the intake is definately cooler than OEM. I think it will be better when fitting an FMIC (maybe). Even better gains expected if you're going BT. Looks cool tho...cheap too :happy:
  11. Dani_B19
    9,365
    400
    So you wouldnt say you've noticed a difference then!
    How easy was it to fit?
    You got any pics?
  12. Lenny Benford
    Lenny Benford snowed under
    167
    I think it will be a waste of your cash dani, your head is an APY which is a small port so it will just be bonnet bling, but its your money.
  13. Dani_B19
    9,365
    400
    Think i read about that somewhere on here but can you explain why etc! Thanks
  14. h100vw
    h100vw Member
    218
    For the inlet manifold to be the major restriction, you would need to be using a large port head. These are fitted on AEB and AGU motors for sure and possibly others.
    To main any significant gains you would need to change the head as well.
    The money would be better spent elsewhere IMO. Either a FMIC or dowpipe would be where I'd go.
    I can't see why an inlet manifold would need a rod change????
    Gavin
  15. Dani_B19
    9,365
    400
    So it is possible to change the head then, or are we talking ££££.
    Definately going tobe getting a fmic soon but just dont know what to get, cant justify forge prices
  16. Dennis Moeller
    444
    Very easy to fit, as I said: it looks cool but I think you'll need a BT kit, FMIC, upgraded hoses etc. to notice any gains. I think fuel economy is slightly better now and intake temp. has definately dropped. I also installed a Phenolic thermal gasket at the same time and that helped bring down temp. drastically as well. So some gains, yeah for sure. A lot of cheap horses...NO!
    OEM vs. Dahlbäck:
    Installed:
  17. Shy19s
    886
    looks nice... get a front mount.. would love to see if this combo makes a difference. dennis what boost are you running?
  18. Dennis Moeller
    444
    Cheers...FMIC is under construction as we speak. Will be on the car in the next few weeks I hope. I'm running 1.4 in 1st and 2nd gear (peaks at 1.5) and in 3-6th gear it's 1.5 bar with peaks up til 1.6...
  19. Shy19s
    886
    Can you hold those boost figures through the rev range with the standard set up? or does it peak and drop?
  20. mat20vt
    mat20vt Member
    450
    my big 007 intake manifold, with R32 throttle body
  21. Dennis Moeller
    444
    Holding the boost figures up through the rev range yes. The peaks were we saw relative high up when we had it hooked up with VAGcom.
    Now were talking :rockwoot:
  22. badger5
    9,578
    2,042
  23. Dani_B19
    9,365
    400
    Will this work with my apy engine then without having to change the head etc?
  24. virdi
    virdi New Member
    17
    at what power levels do you need to start thinking about changing the Intake Manifold on a 1.8T (225) engine?
  25. Darrellspeed
    Darrellspeed Need for Speed
    sorry to revive an old thread but does anyone know where can i get a 007 largeport intake manifold for my s3?
  26. Dani_B19
    9,365
    400
    Either speak to bill (badger 5 on here) or go other to SCN.net and have a look at INA enginerring.
  27. badger5
    9,578
    2,042
    007 is not available these days
    current one is SEM as good replacement, ~$825 and choice of port size and throttle size (throttle is +$$)
  28. Darrellspeed
    HI Badger i 've sent you an email. Thanks
  29. Andrew@A.L.D
    3,879
    617
    I will be making my own soon, just got to get hold of a R32 T/B and once made get it on the flowbench
  30. Dani_B19
    9,365
    400
    Andrew you still making your own exhaust mani?
  31. Andrew@A.L.D
    3,879
    617
    When i get time and the money
    I have a friend that will tig it up for me but he's very slow at getting things done so looking for another good tig welder
